I am getting no responce to my starter when I turn the key , I have installed 2 new batteries and also a new starter. When i turn the key I get nothing. I have a 83 Blazer with a 6.2 Thanks
Hi Captain ;have you checked the neutral safety switch if automatic or the clutch sw if manual?
Use a volt meter to see if you're getting 12v to the "S" or "M" terminal on the starter solenoid with the ignition switched on.
My 1985 CUCV uses a starter relay to supply the 12v feed to the "S" term., so find out if you have a relay, also check the ignition switch itself.
Thanks for the replys , I'll be checking both the safety neutral switch and the relay switch tomorrow
Neutral safety switch , yes it was got it fixed and am ready to go. Thanks
