Hi all,
I've got a question about piston height. Standard piston for a 6.2 and a deck that has had no machining. Where does the piston top come out - below, at, or above the deck? I ask because I've just had my 6.2 block machined(0.008" removed) and the Mahle 6.2L 0.030 (19:1) pistons lie just 0.003 below the deck. I don't know if the block was machined before my latest cut. I'm going to run the + 0.010" FelPro gaskets because head machining also took another 0.005".
Jerry
84 CUCV(Converted to Silverado Package), 6.2L Banks Turbo, NV4500, NP208, Bilsteins, 2400* Jet Hot Coatings, Dual Idler Gear Drive, 97 Cooling Mods, A/C, 3.73 ratio, ARB Locker in Dana 60, Racor 45, Electric lift pump, Sirius Sat radio, Refurbished drive shafts - 20.5 MPG<br />Mods awaiting funds - Electric Brake Controller, Paint job/body work,
