I would like to replace the shock absorbers on my 1985 6.2L Suburban. It originally came from the factory with the quad shock option. If I wish to use only 4 shocks total (2 on the front, 2 on the rear) which shock mounts should be used on the front?? The inner shock (shorter?) or the outer (longer?)
Any suggestions on shock type wouyld also be appreciated. I do some light towing (3000lbs or less)
Mike
1985 K20 Suburban 4X4 <a href=\"http://www.karensphotos.com/suburban\" target=\"_blank\">www.karensphotos.com/suburban</a><br />6.2L \"J\" code<br />TH400 3-speed Auto<br />3.73 rear
