FYI, I'd like to share my experience to help you avoid similar problems:
I previously posted that my timing chain had over 1" of play and that dual idler gears were fitted. After installing the gears, I had to set the pump timing about 1/16" to the passenger side of timing cover mark to get TDC @ 1400-2000rpm.
During the gear installation, I decided to winterize the truck in preparation for a high altitude camping trip, so the glow plugs were pulled. #3 and #6 glow plugs had melted tips which is evidence of pre-ignition, all of the rest were in good shape.
Since I have always run TDC @ 1400rpm with these glow plugs, my conclusion is that at certain engine speeds, the worn chain allowed enough play that an additional "?" degrees of advance was being added to the injection point on these 2 cylinders.
During driving when the chain was still installed, the engine would vibrate quite strongly in the 2300-2800rpm range and it wouldn't sound right. Since the gears were installed, the engine is smooth at all speeds.
YMMV, but if you don't know the condition of the timing chain on a high mileage turboed engine, use caution when advancing the timing; higher boost pressures ensure a very hot, quick and consistent burn and if the chain allowed certain cylinders to be too advanced, it's unlikely that this would show up on the EGT meter - it sure didn't on mine.
I just got back from that 600 mile camping trip involving WOT driving at altitudes of 8700', EGTs occasionally peaked at 1100F and boost levels over 14psi. I checked my glow plugs afterward and they are in perfect shape, thanks to the consistent timing provided by the dual idler gears.
[ 10-08-2003, 11:27 AM: Message edited by: britannic ]
