I was towing my friend's CJ5 this past weekend, and the EGT was a little on the warm side at 900F with boost topping out at a disappointing 3 pounds. This is on the flat highways of Texas, so something was definitely wrong.
I got to Dallas, and upon inspection, I found this.
Sorry for the light, but you can see that the 3/4" ID rubber caps that cover the old CDR fittings on either side of the intake experienced, as my father put it, catastrophic failure.
We couldn't think of anything like the caps that Banks provided, but we did have some of the right sized heater hose laying around. That stuff can handle around 20 pounds, so it was chosen as a temproary fix.
The intake was vented to the atmosphere for the first 200 miles of the trip, so you can imagine my delight with the next 250 miles. The EGTs were steady at 650 on the flat parts, and up to 900 on hills. I finally got to see my wastegate open on the boost gauge at around 10 pounds, so that's going to be turned up to about 12 or 13, and we'll see how that goes.
The next upgrade on the menu will be a new O ring for in between the intake and boost plenum. Thanks for the part number, Peter.
