Will the typical arrangement of 4 tranny bolts on an engine stand support this engine? I have my 6.2 out and I want to R&R the timing chain and gears, valve cover gaskets and also possibly change the rear main seal. Any other regular maintenance issues I should perform at this point? My compression is good at 400 psi each cylinder.
Thanks, Richard
