I've got a nice oil leak originated between the timing cover and the front of the oil pan. I would like to drop the pan to repair but not sure how possible this is with the cross member in place (4x4 model). Is this possible or should I pursue drilling the rivits to remove the cross member and replacing with bolts?
Of course, the leak occurred after I reassembled the front of the engine for my timing gear installation. Bad gasket area prep work on my part!
