Thread: 2003 Duramax Diesel clunk
    Jul 2005
    Galveston
    I get a drive line clunk at operating tempatures when starting and stopping. Noticed mostly at take-off. Does anyone out there have a fix? I would appreciate any advice on the matter.
    Jim Brzozowski Guest
    Check the u-joints on the driveshaft for wear.
    Jul 2005
    Indiana
    Could be u-joints, or something else. Where is the clunk coming from? ie. front, back, left, right, etc.
    2003 GMC 2500 Crew Cab 4WD Silverbirch All Stock.
    It is very likely your output spline is in need of some grease. When you stop, spring wind-up occurs in the leafs. When you take off, the spline sticks, then releases in a "clunk", as the springs swing to the other extreme. GM's "fix" for this is to grease the spline with a HP lithium grease.
    I'm moving this topic to the Drivetrain Forum.
    [ 07-29-2005, 06:34 PM: Message edited by: DmaxMaverick ]
