First Diesel....hope you are not one of those guys who never goes to the doctor for a physical, because you don't want to hear something might be wrong LOL
The first oil change should show the highest numbers as all the waste and sand and crap from the casting and buildup are washed out. After that, subsiquent analysis should read normal. If they don't read normal it means there is something you need to keep an eye on (just like high blood pressure or high cholesterol). If subsiquent analysis (testing) continue to show no improvement or worse readings then further testing may be necessary. Unlike our bodies, these trucks come with a warranty and if you can document an issue, the dealer has to make it right.
Most major diesel operators (big rigs and heavy equipment operators) live and die by the maintenance schedule and oil analysis as the "early warning system" that something is going on and needs to be addressed. Our trucks are smaller, but the same principle applies. Periodic analysis (not necessarily every oil change, but some will do that)can be considered preventive care so that you can take care of a problem before it gets worse. Think of it like a clogged artery in your heart's pipeline, do you want to know about it while there is still time to do something about it or do you want to just fall down and die one day. When we die it's all over, but when our trucks breakdown, it's just expensive. So consider the oil analysis like a doctor's visit for a checkup once a year or more.
Enjoy that new truck and yes you will be doing new things that you never did before in your gasser. But that's what makes it fun, to learn new things and take better care of your investment.
Have a great and healthy day!
\'01 Chevy EC/2WD/SB, T/F 45 gal, Delvac 1, TranSynd, deep pan, MAG drain plug. Escalade handles & painted bumper capto. After market grill, billet bowtie, Stockland cover, no side trim, no juice, no gauges, nuttin but stock! Nicktane Big CAT Pre-OEM. Gone, but not forgotten.
'07 Crew Cab LBZ stock all the way except added 45 gallon Transfer Flow tank and billet grille. Great truck also now gone, but not forgotten.
'12 Crew Cab stock for a few more days LOL
