I'm considering changing over to synthetic motor oil, probably Mobil Delvac 1. I've got over 16K miles now. I intend on running 7500 miles between changes with the synthetic and many suggest to do oil analysis if running that long between changes. Here are some of my questions:
1) where do I get the oil analysis kits.
2) which company does a good job of interpreting the technical results and gives you meaningful info.
3) should I have an analysis done of my dino oil when I switch in 2000 miles.
4) doesn't the soot build up with 7500 miles between changes.
5) what about the acids that gassers supposedly accumulate if the oil isn't changed every 3 months. Do diesels build up acids after 3 or 4 months?
Sure am glad this forum exits to get good info.
Thanks in advance.
2002 Silverado 2500HD,D/A,LS,ext cab,4x4,pewter,Truxedo cover,Line-X liner,Lund running boards,Bilsteins on all 4 corners, Air Lift air bags, Tekonsha Prodigy brake controller<br />2001 Honda Goldwing, pearl blue, 118 hp<br />2001 Coachmen Royal 32 ft travel trailer, double slide-outs<br />Toy Trax bike loader
