Getting high idle installed tomorrow morning. I here it is different than 2001. If anybody has instructions on this PLEASE e-mail me @ bearengy@telusplanet.net . By the way, my new 02 dually rocks way better than my 01 did
Cheers
Bear
Cheers
Bear
Summit white 2002 Chev 3500 LT 4X4 CC Dmax, Outback stainless steel bushguard, KC Daylighter titanium offroad lights,110 gal. auxellery fuel tank / tool box combo, Lund bug deflector,DeeZee stainless steel grill insert, Dee Zee stainless running boards, Husky front and rear floor mats, Wabasto diesel fired heater, Juice 4.61, Lucerix X-Mount Mirrors, BD Exhaust Brake,Prodigy Brake Controller, BD X-Monitor, Kennedy Diesel light harness, Bilstiens shocks Alcoa Hot Shots with Michilin 235-85R16 LTX AT. pull a 30.5 ft Avion Westport 5th wheel trailer and a 2000 18FT Tahoe Fish and ski boat with a 4.3Lt LX in tandem, many more toys to come
Same but different. Same pin/connection etc, just no standby speed unless programmed in, and IF you program, it will run funky and oscillate between balancing and not on the fuel injection map.
Good to hear you like the 02!!! We finally got another happy camper here. Anyway check your mail, I sent you a copy. Kennedy is right, installation wise there is no difference between a 2001 or a 2002, you just loose the 850 standby speed.
Thanks guys, that prety awsome, 2 replys in 13 minutes
Cheers
Bear
Anytime brutha!
DSLPOWR ,
Could you please e-mail me the same info for high idle in 2002's . My e-mail is sdilliot@ciaccess.com . Thank's in advance !
2002 Chevy 3500 , Crew Cab , Pewter, 4x4 ,Duramax / Allison ,TechTube Stainless Steel Wheel to Wheel Step Bars , Husky Flaps ,A.R.E. Z Series Cap ,<br />Eagle Flight Wheel Simulators with Factory Centres , K&N Air Filter ,PIAA Headlights , High Idle installed
Sent.
Would also like high idle information for my 2002 .my e mail kwitherspoon@shaw.ca. Also bearman you from alberta im from calgary new 2002 3 days love it.
Thanks DSLPOWR , appreciate you sending it so fast.
kerri- sent!
DSLPOWR,
Could I trouble you to send me the high idle info for the 2002? Thanks a million. My email is mcbridks@bp.com.
Best Regards,
Kevin
2002 2500 HD, LT Trim, CC, 2wd, longbed.<p>Upgrades: Kennedy 4\" exhaust, BD Dynomite box, 100hp propane kit.
Sent.
DSLPOWR,
Would you mind sending the High Idle info for the 2002 Duramax one more time? n5hty@centurytel.net
Thanks,
redmax
Red 2002 GMC Sierra D/A 2500HD<br />XM Radio, Dual Alt., Delvac 1, TMD700A Amateur Radio for remote base operation
Sent. Anyone else?
Hello DSLPOWR
I would also be interested in the this for the 01 Dmax. My e-mail is justlabs@nowonline.net
Thanks in advance
Brian
Blue D/A 01 Ext.Cab LS 4x4,A.R.E. Cap,Bedliner,<br />And a grin that I can\'t get rid of :-}])
Sent.
DSLPOWR, Since you mentioned it I wouldn't mine getting that info. My email is nate7161@yahoo.com
Thanks alot
2002 Chevy 2500HD Dark Carmine Red/Tan D/A CC SB LS G80 4x4,<br />Reese 16k, Speedliner, Stainless Works Nerf Bars, <br />Hayes Brake Controler with Remote, AS&L Crossover Box,<br />GM Mud Guards, and one piece Driveshaft<p>Pullin 2002 Gulf Stream Conquest 29\' 5th wheel
Sent.
DSLPOWR
Me to please. mikem@celgar.com
Sent.
