Thread: olds 350 diesel for f-150
    Jan 2016
    Russia, Moscow
    Default olds 350 diesel for f-150
    Hello to all present here. I'm starting the conversion of my Ford f-150.going to install an olds 350 diesel from an old Chevy truck instead of the original gasoline 302 Windsor 5.0 . Now I do prevention engine , new timing chain ,ARP head studs, new gaskets and seals. in the process I will add pictures in a photo album. I have a DX block, head D3A and a pencil nozzle. I have uploaded to YouTube a video test run after I bought this motor.
    Sounds like an awesome project!
    Jan 2016
    Russia, Moscow
    I was curious to try to install the diesel engine. I was standing in Bronco Mercedes 603 diesel (3.0) atmosphere interlocked with a manual transmission Mitsubishi Pajero. but in an American car I wanted to install an American V-8.)) we are here in Russia cranks.
