Fluidampr and crankshaft pulley
Searched the forum and couldn't find an answer to this question: If you replaced your oem HB with a Fluidampr, what kind of crankshaft pulley would you get to replace the oem pulley? I want to replace both of them, not sure whether to get a new AC Delco crank pulley or go with one of these solid billet aluminum crank pulleys like Leroy Diesel sells. Seems to me the original crank pulleys are made the way they are for a reason. But with a Fluidampr and solid aluminum crank pulley combo the problem of deteriorating rubber would be eliminated I would think. Would the solid aluminum pulley cause premature belt failure or extra wear and tear on the serpentine belt system since it doesn't have any dampening built into it? Any advice would be appreciated. Thanks.
'95 GMC Sierra 6.5TD C2500, reg cab, long box, 2x4, 4L80E, 3.73 ratio, VIN F, L65, 130K. Mods: DE 4" exhaust/crossover, WW2, PMD relocate, Dmax fan/clutch, AFE Magnum FORCE intake, Fluidamper 800141, LP Relay Harness w/WTS priming
