Results 1 to 2 of 2
Thread: 2005 Mitsubishi Fuso FE 180
    Jul 2021
    New York
    Default 2005 Mitsubishi Fuso FE 180
    These codes came up. Anybody know what I should be looking for. The motor has 225k
    I’ve worked on regular gas engines this is my first with diesel. I changed the fuel filter housing. Reconnected the muffler with a new engine pipe. New thermostat. New air filter. On warm up very little power. Then it seems to have decent power. It was overheating. Changed the thermostat and it appears ok so far I will replace the radiator cap. The truck sat for 2 years before being driven. After I purchased it and did some restoration I drove it 150 mile to its present location in the mountains of Massachusetts. I’m taking it to Tucson within the next several months. That’s where I’m moving. Any direction would be greatly appreciated
    PO254
    335
    381
    404
    251
    P 1635
    P1630
    Hello
    Welcome to TDP
    The P0254 is possibly as simple as a dirty fuel filter.....
    With all the codes listed I would do the following.
    Clean the battery terminals and make sure the battery/batteries are well charged.
    Changed the fuel filter/s and purge/bleed the air from the system per the manufactures recommendations.
    Grab a scan tool and clear all the codes.....
    Run the engine and drive the rig......see what if any codes come back.
    With so many codes it is not wise to start "Chasing the Wind" so to speak and tossing time and money at things until you get a real handle on what is really happening.
    Good luck....
  1. fuso fk-102
    By daviesgroup in forum General Diesel
    Last Post: 11-30-2018, 16:53
  2. mitsubishi swap
    By DIESELDALE1 in forum Diesel Conversions & Swaps
    Last Post: 02-11-2013, 23:14
  3. Replies: 0
    Last Post: 01-21-2013, 15:24
  4. Mitsubishi diesel - Fuso
    By Jeff71 in forum General Diesel
    Last Post: 12-06-2009, 06:49
  5. 2005 changes??
    By rickdlance in forum Duramax 6600
    Last Post: 06-25-2004, 11:02
