Any thoughts about fuel additives? I've got 6k miles on my '02 D/A now. A buddy is telling me I should be running some through with every tank to keep the injectors clean. This is after he had to replace a piston in his 6.5L (w/ 22k miles on it) after an injector clogged.
Thoughts? Opinions? Has this been discussed before? (likely)
--Rob
FPPF total power or fuel power. Sometimes hard to find, but worth it. Truck stops sell it. Last a long time as well in a small bottle.
2001 GMC 2500HD SLE AlliMax, Longbed, Ext. Cab, 4X4 Summit White, G80 Differential, Husky Liners, Black UWS Toolbox, Black Westin Nerfs, Black Replacement Front and Rear Bumper, JL Audio, Hella, Cobra, Goodyear 265/75/16's, Tekonsha Prodigy Controller, Fumoto, Rhino Liner, 400 Watt Inverter
KENNEDY 4" Exhaust: INSTALLED!
UPDATED PHOTOS
My truck is faster than Pullinpower's. Period.
SoMnDmax...here I come!
I sure wished I lived in Lawton, OK so I could work on my truck in Mdrag's Shop!
GM does not recommend additives. Many use an emulsifier to blend water with the fuel so it can be burned, this will prevent the water separator from removing it. If the water is makes it past the water separator and is introduced to the fuel system parts it can cause rust and corrosion in the pump, injectors and other components. With the close tolerances of today
I've been using FPPF Total Power since September and also add some of their 8+ Cetane Booster to each tankful. I add 1oz. of each for each 5 gal. of fuel added at fill up, rounding off to the low side.
All I can say is this stuff does work. The truck runs better than ever.
Jack Schultz, McKean, PA
jackschultz@adelphia.net
http://photos.yahoo.com/bc/jack_schultz2001
2001 Chevy Silverado, 4-WD, 2500HD, Crew Cab, Short Box
LT Trim, Black Onyx w/ Tan Leather
Beltronics 980 Radar Detector
The shop manager that services my truck told me GM will not warranty a Duramax fuel pump if there is evidence an additive has been used in the fuel. I was going to add an fuel additive for my trip to Kansas,but after talking to the shop manager I took the additive back to Tractor Supply and got my money back. Those diesel fuel pumps are expensives
I gotta say that policy is some of the STUPIDEST stuff that I've heard!!!
Just how many premium diesel stations do they think there are that do NOT use additive to make it premium???
Alcohol based additives (PS) are a definite no-no, but come on, when injection mfrs distribute the stuff...
John Kennedy
www.kennedydiesel.com
John@kennedydiesel.com
2002 Chev. K2500HD Dmax/Allison Crew Cab Long Bed Pewter/Tan LT Driving it!!!
1996 GMC K2500HD 6.5TD Ex.Cab LWB 260+ Rw H.P.
1984 K30 SRW 6.2NA Headers and custom 2 into 1 exhaust FOR SALE
'01 FXDWG Black/Chrome Yellow (2 into 1 Thunderheader <naturally> (100+ RwHP)
"If I had to explain, you wouldn't understand"
You can get more misinformation from some GM service advisors on Duramax Diesels than you would expect from your average old maid librarian. Unfortunately, some of them don't know their a** from deep center field.
I've seen a GM bulletin at Diesel Injection Service endorsing the use of Stanadyne Fuel Additive.
2002 GMC 2500HD D/A, Crew Cab, Short Bed, Pewter with Pewter SLT Leather, Westin Stainless Nerfs, Line-X Bed Liner, Fumoto Valve. Run GM Synthetic Diff, Chevron Delo 400, Amsoil air filter, Stanadyne Performance Formula and Allison/Castrol TranSynd.
I went on trip to the snow and got a can of STP fuel additive just in case it got to cold. I did not have to use it it was very warn. But I like the idea of better mileage and keeping the my truck runing great. So what is the right stuff to use? The cans all look the same.
Thanks BIll
Bill,
Stay away from the stuff that claim they rid the fuel system of water for the reasons that D-Max man stated.
IMHO you are much better off leaving the water seperated and letting the filter do it's job.
2001 C3500 Charcoal Grey
Putco Boss Boards
Putco Virtual Grille
Stainless Sill Protectors
Stainless Exhaust Extension
SPA DG-111 Boost/Pyrometer
Whistler Radar Detector
600 Watt Inverter
Compaq Lap Top W/Moving Map
250 Watt Texas Star Linear Amplifier
Cobra 29 Classic CB Peaked W/Echo Card
102" Steel Whip
Cross Bed Aluminium Tool Box
Catch All Mats
FPPF. As I said above, Some truck stops sell it, and you can also check out www.kennedydiesel.com Get his number, and give him a call.
UPDATED PHOTOS
All I can say is that it "does work", and it makes the truck run better. What do you think the "good" diesel fuel distributors put into your fuel? Additives . . . particularly in the winter months to prevent gelling. Same thing as FPPF. Also some put other lubricants, cleaners, plus cetane boosters.
The fuel distributor who handles BP and Shell plus many of the other private trucking companies in our area is the only one who puts in a cetane booster. Standard diesel is only 40 cetane, that all. Pretty crummy stuff on its own. Erie Petroleum puts it's additives in to get to 45 cetane. I add a little more to push it closer to 50. That's where it should be anyway.
If we were all running 50 cetane fuel, there would be much better and more consistent performance in all our diesel trucks. Why do you think there are so many different performance stories out there, good and bad . . . fuel is a huge contributing factor in a diesel.
The reason GM tells us not to put in additives is because there are some really stupid people out there who might add an entire quart or so at a time to their fuel system to "tune it up". I've heard some of these brilliant discussions at the bar from those guys who may never have counted past 10 in their life. GM is protecting themselves from these idiots, and I don't blame them.
But, seriously, think about it, additives are the best thing, particularly for your diesel engine. Heck, we used to put in stuff called "Diesel Pep" back in the 60's. All the owner-operators used that stuff way back then. It helped then also.
[This message has been edited by Tader Jack (edited 01-16-2002).]
Now wait a minute! It gets cold were I live, and where I go, and without some diesel fuel treatment, I would not get far in either my Chevy Duramax, or my Volvo Detroit 12.7ltr cause my filter would be plugged with wax.
I use Howes' Diesel Treat, which does NOT emulsify water, but does just the opposite. Howes' Diesel Treat de-emulsifies water which ensures any water reaching the fuel/water separator stops at the filter.
I highly doubt GM would dispute a warranty claim because I used a diesel fuel treatment so I could start my engine, specially one which removes water from the fuel before the pump and injectors.
It is absolutely true that some kinds of diesel fuel treatments should not be used in a Duramax. Anything containing alcohol or water emulsifiers should never be used.
And as a matter of general interest, my Volvo highway tractor averages 5.6 mpg on a 1400 mile round trip in winter without Howes' Diesel Treat vs an average 6.6 or better with. Without in winter I change my fuel filter every 3000 miles or so, vs 15000 miles with.
I can see the difference!
01 Chev K3500 D/A LT Crew LBx
Diesel Page Member #40
It's kind of funny we keep bringing this subject back up. A while back Kennedy gave his two cents on the subject. You guys need to listen. I've only been part of this group since last Fall. But when I see a post from Kennedy I make sure I read it. Now I don't know Kennedy, and may never know him, but I feel anything he says along the lines of diesels is on the level. People with his background are a very big plus to us all.
O.K. I'll get off my box now. I called a Rep. from FPPF awhile back to find a location to get there product. He told me he would be coming though my area over the weekend. Sure enough, on Sunday he stopped at my house to talk with me. He gave me a list of places to buy and left me with 6 bottles of Total Power to try. Now that's what I call a good Factory Rep. I don't know too many parts stores that would just give you their product to try for free!
Thanks to the wise ones,
SHOPMAN426.
Mike.
2002 GMC SLT Summit White 4x4 Longbox Crewcab 2500HD.
Duramax 6.6L and Allison 1000 Series 5 Speed Auto.
All the Bells and Whistles right down to the heated seats.
ACCESSORIES
<LI>Cooper 265x75 16R Tires.
<LI>16x8 Typhoon Weld Wheels with aluminum lug covers.
<LI>Bars cranked up for 265's.
<LI>GT Classic Hard Tonneau Cover by Gem Top.
<LI>Airlift air bags.
<LI>DTA Corp. running boards.
<LI>KaydenCo mudflaps front and rear.[/list]
ACCESSORIES to be added
<LI>Rhino spray in liner.[/list]
O.K what do you think of this suff.
RED LINE 15W40 DIESEL ENGINE OIL: Your diesel engine needs more internal cleaning and acid neutralizing than a gasoline engine and that is why you should use diesel engine oils. The high detergency of diesel engine oil will ensure long haul, high temperature protection as well as short trip protection by minimizing deposit build ups. API rated CH-4, CG-4, CF, SJ, EO-M
This oil is available in quarts or gallons. For use in diesel engines only.
RED LINE
Simply put:
Add 1 part FPPF Fuel Power to 1 part water and shake. You can also do this mixed in with diesel fuel.
Now TRY to find the water with that goofy paste that the fuel stations use. You just plain WON'T! I have the kit that does this demo.
Now I have seen DS4 pumps with severe water damage. Guess the filter didn't do such a good job of straining out the water...
John Kennedy
Shopman426,
Please share that list of locations the FPPF Rep. gave you. I will be passing through the Portland on my way to the coast tomorrow.
My email address is ejscott@skyride.net
2002 2500HD ExtCab LB 4X4 LT D/A
[This message has been edited by et (edited 01-16-2002).]
If you live in the Toronto area you can get FPPF TOTAL POWER from ADP Distributing 1-800-601-7888 12 BOTTLES $156.00 each bottle good for 250 gal. Also if you go to Canadian Tire they have a plastic bottles comprised of a lower portion that holds the additive upper portion has a graduated 100ml reservoir (1/4 graduation == 5 gal or 20 liters), (you squeeze the required mix from the lower container into the upper container and then just pore no fuss no mess). Research what your buying in this area as a couple of the diesel fuel additives sold do not have anti waxing or any centain improver.
PS. the bottle I described is full of car fuel injector additive.
I've used the Stanadyne Perforamnce additive in my diesel. Tell you the truth, I can't tell the difference in performance, sound or MPG's. I've been tracking my MPH tank by tank since my truck was new (67K miles ago) and the Stanadyne hasn't made one iota difference in MPG's.
I just tried the RED LINE
I was wondering about this also. I would like to run Stanadyne lubricity formula in my Dmax just like I do in my 6.5L. I understand that the low sulphur diesel used here in California is harder on fuel systems. I would like to start out on the right foot and give the injectors the most amount of life I can.
I was wondering if the additive may do something to my catalyitc converter? I have a sticker on the inside of my fuel door which says "low sulphur diesel only". Does everyone have this sticker or is this just for CA models? Wonder if it has to do with the cat?
Matt B.
mattb5150@hotmail.com
1993 K2500 HD ext.cab 4x4 with Banks Exhaust, Turbo Technologies mandrel bent crossover pipe, DSG Gear Drive, cooling mods, Bill Heath Turbo Master boost control, Isspro gauges, K&N Filter, Bilsteins.
1993 K3500 ext.cab single rear wheel 4x4, snorkel removed. Isspro EGT Gauge and Boost Gauge, Amsoil Filter, Banks Boost Lever, Rancho RS 9000 shocks with in cab controller. For Sale.
2002 GMC K2500HD SLE CC/LB DMAX/ALLI, Summit White, aluminum wheels. Husky liners. Amsoil TS 123 air filter, Fumoto valve, Covercraft seatsavers.
[This message has been edited by mattb5150 (edited 01-17-2002).]
