george morrison
originaly posted under "fuel filter replacement"
[if this filter is installed improperly ("O" ring rollover, etc.)fuel, as with water, will always find the easiest way through a channel which translates into just what our analysis indicates:]
The "O" ring roll over confused me, are you refering to one of the two "O" rings on the out side of the fuel canister or that large internal ring in the center of the fuel canister.
If you could expand on this subject it would be much appreciated
GMC 2002 DURAMAX, SLT, EXCAB SHORT BOX 2500HD, 4X4, AUTO
ACCESS TONNEAU COVER, 3" STAINLESS TUBE STEPS
JORDAN BRAKE CONTROLLER
34ft 10,000 lb TRAILER, 50 GAL TRANSFERE FLOW TANK (total 76 gals)
