Results 1 to 15 of 15
Thread: more fuel filter
    Dec 2001
    Nampa,Id USA
    About the middle of April, someone posted some pictures of a post OEM filter mounted on the A/C bracket. I believe it was a Racor. How did this installation work out with regards to the air lock problem.I am considering installing one & I remember this looked like a easy one to service. Does anyone have the URL for this installation. I can't find it in search.
    chipper 2001 GMC,,D/MAX,SLE,EXT CAB,LONGBED,LINEX,FIRESTONE AIR BAGS,,driv\'en it & smilling, 32' Excel 5er
    Ct.
    Lone Eagle .....
    Mac
    mdrag Guest
    Cool
    Check Lone Eagle's RACOR ENGINE MOUNTED FILTER post.
    Jul 2001
    Tremonton, Utah, USA
    Smile
    chipper, I just took a fuel sample tonight and will send it to AV Lubricants tomorrow. I have 9,500 miles without an air/vibration problem. Some that originally liked the location have since voiced concerns about engine vibration changing the filtering quality. I decided a fuel analysis was in order. Should know within the next week. If the results are favorable I will repost the photos. Later! Lone Eagle
    02 2500 HD EC SB<br />Juice 4.61<br />Post OEM Racor 660<br />Back Country Bars<br />Roll Lock Cover<br />B & W Turnover
    Jun 2002
    Birmingham, AL
    Could you re-post the pic's? I can not seem to get them to pull up?
    Thanks,
    Burner-------&gt;
    2003 GMC SLT CC 4x4 SB-Cooper Tires-Speed Liner-Activator II-Full length ICI SS step bars B&W Goose & more to come
    -- Member #7527
    E-Mail --&gt;Twomuchplay(at)AOL(dot)com
    Dec 2001
    Nampa,Id USA
    Thumbs up
    Thanks Lone Eagle.I will wait for your results on the analysis & happy to hear you didn't have any of the "trapped air" problems.
    I can't imagine engine vibration having any effect on the filtering as CAT mounts theirs on the truck frame which vibrates as much as our engine.
    Boothwyn, Pa. USA
    Engines are mounted on isolation devices. Vibrations cannot be categorized as simply vibrations. There are different types. Studies were sponsored by CAT and it was determined that engine vibration does in fact effect filtration.
    A vehicles frame has much different vibration frequency characteristics than the isolated engine itself. Frame vibrations are dampened significantly by suspension components.
    The engine itself has direct cumbustion triggered knock that is probably one of the worst kinds of vibrations for a filter medium.
    columbus, ohio
    CAT found that the vibrations issues are not from the engine vibrations specifically but moreover the harmonic 'feedback' vibrations in the fuel itself. As the injectors fire, pressure builds, releases, those impulses are transmitted back through the fuel medium itself, creating an almost 'ultrasonic' cleaning of the filter medium. This is what necessitated CAT switching from an 8 micron beta 2000 filter medium to a 2 micron beta 2000 medium, laboratory test procedure as the theoretical 8 micron filter should have captured the wear causing 5 to 10 micron size component. However, real world pump and injector life was still unacceptable and CAT went back to the lab to determine just why the 8 micron filter was not capturing 8 micron particles. Thus came the discovery of the back-feed, filter media cleansing phemonena.
    Which is very likely the reason we have the unacceptable OEM filter medium on our Duramax. The filter IS a 2 micron beta 200 or so filter IN THE LAB... Real world, quite another matter..
    George
    George Morrison, STLE CLS<br />www.avlube.com e-mail avlube@netwalk.com<br />2002 Chev Duramax 2500HD, Delvac 1, Mobil 1 syn ATF, 75W-90<br />1998 Chev 3500HD 6.5TD, Delvac 1, Harvard 750S by-pass oil filter
    imported_ Guest
    I had misinterpreted your original report of the injector pulse filter cleaning phenomenom to be siomething beneficial.
    For example, I erroneously thought that this pulsation cleaning would give the position of post-OEM add-on filters an advantage over pre-OEM add-on filters.
    Consequently, do you think that when using a pre-OEM add-on filter, that the factory OEM filter would help buffer the pre-OEM filter from these harful injector pulsation?
    Apr 2002
    Sacramento, CA
    George,
    Thank you as always for your expertise.
    How far down the fuel lines would another filter have to be in order to avoid the "harmonic vibrations"? If they really do decrease the filter efficiency, would it only happen when the engine was running? Specifically would fuel samples taken via priming pump or operating the lift pump (engine off) show better results since the engine was off and the harmonic vibrations not present?
    [ 08-21-2003, 12:48 PM: Message edited by: ndamico ]
    Jul 2001
    Cool
    I picked up a little info from a friend who owns a diesel service center but I am going to sit on it until my sample results come in. I am already out on a limb but not so far I can't jump back without loosing face. Later! Frank
    Aug 2001
    Santee, CA
    Talking
    Come on. you can tell us. We won't tell a soul.
    Regards, Steve
    Jan 2002
    La Selva Beach, California
    Rumor has it that your friend bought a MEGA
    02 Chevy 3500HD, D/A, 4x4, Lucerix Mirrors, Fumoto valve, Amsoil air filter, <br />Kaydenco mudflaps, Hadley Air Horns, Lund Hood Protector, Prodigy,<br />2 micron Racor Post OEM fuel filter install photos:<br /><a href=\"http://community.webshots.com/album/66562661oghYok\" target=\"_blank\">http://community.webshots.com/album/66562661oghYok</a>
    Jan 2002
    Wink
    But he is looking for a good lift pump..........
    Boothwyn, Pa. USA
    Careful when comparing the results of studies on CAT engines with none done on the Dmax. Our injection system is totally different. I would venture to guess our system has a whole lot less injection pulse harmonics than a big CAT with HEUI injection (remember only guessing). Our system has a pump specifically designed to minimize pulsing and large fuel rails that help absorb them. And since any filter is located before the pump and rails, there is even more isolation.
    I thought I posted this yesterday? Anybody see where it went?
