5.9L Cummins in 93 Chevy 4x4
what an extensive conversion.
I've had the engine set, bolted up to the NV4500 for about 2 months now, lacking only time. Can't seem to get any time from work (ah-a fellow complaining he has a job..) I plan to do the remainder of the conversion in July on my vacation time.
--driveshaft has been shortened and balanced. $38 (good price)
--Need to line up cross members and drill holes. EZ.
--140 AMP Nippon Denso alternator converted to internal regulator and tach pickup $75
--need to pull the PS pump and braze in a 3d return fitting.
--still have to fit and plumb the Dodge cummins intercooler.
--still have to order 2"body lift kit. Can't close the hood now. Will also provide room over the transmission bell housing area for work..
Who has the best 2" body lift kit?
Wayne
93 Chevy 4x4, 1 T 5sp Diesel Depot 18:1 ceramic & graphite coated pistons, balanced 6.5TDA, Ceramic lamenated head & exhaust manifolds, Marine 300 HP pump, hi-pop injectors, GM8 turbo with custom manual boost controller; intercooled (19 LBS BOOST), big exhaust, hi-output water pump & dual thermostats, programable glow plug controller, 60G glow plugs, Custom boost & pyrometer gages mounted in former flip-out ash tray, 50 gallon external fuel tank 900-1500 cruising range, goose, RV and receiver hitches; all-in-all--just a little modified for towing. <br />85 Mercedes 300SD <br />81 VW DIESEL Pickup - my sweet & immaculate high MPG daily driver <br />66 Bronco (itchin to put a Mercedes 5 cyl into)<br />59 Dexta with 3 banger Perkins Diesel<br />81 Ford 4X4 Compact Diesel tractor<br />I\'ve driven only diesels since 1979-I think I am a convert. <br />DP # 1146
