Results 1 to 20 of 157
Thread: Transfer case leak repair?
Threaded View
  1. #10
    Jan 2006
    Weatherford Texas
    In the above photo the spring that came loose or broke off wore a small hole at the indention left and back there you see the wear.
    Above and close to the center of the photo you can see the hole about 3 inches above the 3rd bolt and right below the dirtiest part of the case.
    Just picked up truck from service dept. with a $1,280 bill.
    The problem was a spring came loose from fluid pump inside the transfer case and caused the tention to wear a small hole in the rear half of the transfer case at the drive shaft.
    Steve
    [ 01-28-2006, 03:49 PM: Message edited by: Renomax2001 ]
    2001 2500HD Crew Cab SWB Western Diesel Chip, Fumoto, K&G air filter, Ranch Hand
