Has anyone done a rear drum brake to disc brake conversion on a full floating GM axle?
As most know the rear drum brakes are the pits! Been through different lining, new upgraded proportioning valve, adjustmenst seem to make a small improvement for about a week. I did some searching on the net and found some kits, some with very little in componets, and some with new master cylinder, proporting valve, hubs/bearings tubing etc. but with a hefty price tag.
Tom McCauley (DP Member #513)
"Tankers-ToyII" Loaded 05 D/A K-3500 CC, SRW. Deep pan on Allison w/Transyn. Edge Juice w/attitude, 4" Kennedy exhaust, 98 Gal. Transfer-Flow cross bed fuel tank, Leer 100XQ bed cap. Reese 14,000lb class V hitch w/ dual cam HP sway control. Tow 34ft. 32FKD Holiday Rambler travel trailer. GCW 20,360lbs
