Cummins Powered Chevy
She runs. [img]smile.gif[/img]
Still tinkering with gages, but have it all figured out.
Have yet to have the heart to cut up the front end to install the cummins intercooler. Have it, but won't use it. Using one mounted near where 92-01 chevy intercoolers mount, and with the 2" body lift, there is a ton of space to mount an intercooler.
Wayne [img]smile.gif[/img]
Road test went well.
[ 08-03-2004, 03:48 PM: Message edited by: DogDiesel ]
93 Chevy 4x4, 1 T 5sp Diesel Depot 18:1 ceramic & graphite coated pistons, balanced 6.5TDA, Ceramic lamenated head & exhaust manifolds, Marine 300 HP pump, hi-pop injectors, GM8 turbo with custom manual boost controller; intercooled (19 LBS BOOST), big exhaust, hi-output water pump & dual thermostats, programable glow plug controller, 60G glow plugs, Custom boost & pyrometer gages mounted in former flip-out ash tray, 50 gallon external fuel tank 900-1500 cruising range, goose, RV and receiver hitches; all-in-all--just a little modified for towing. <br />85 Mercedes 300SD <br />81 VW DIESEL Pickup - my sweet & immaculate high MPG daily driver <br />66 Bronco (itchin to put a Mercedes 5 cyl into)<br />59 Dexta with 3 banger Perkins Diesel<br />81 Ford 4X4 Compact Diesel tractor<br />I\'ve driven only diesels since 1979-I think I am a convert. <br />DP # 1146
