We will be limiting to a handful of trucks for Saturday and doing more of a laid back hands on approach where we try a few of the various tuners/modules and see how they compare. I've got a pretty good selection of demo stuff. After seeing how "old" it seems to get after seeing so many different trucks run on a dyno in succession, I kinda thought a fresh approach was in order. This would give time to explain some of the test method, and what the results mean. I'm sure we'd also want to strap my truck down for a 600+ HP run as well.
Eric and I are looking at quite probably doing an Allison upgrade as well on Saturday. Eric would do the job, and we'd break away and observe him install the upgrades once he had the trans removed...
I'm hoping to have an Allison on a stand to tear down, as well as a transmission kit to show the various components available.
Should have my "magic" pump circulating fuel in a tank by then as well.
Should be at least 2 GM technicians in attendance. Not sure if Dennis will get his hands dirty, but Eric will be doing some dirty work...
Directions from Loyal WI
Take Cty K south of Loyal just about 1 mile. Where K curves west, you drop off fwd onto gravel. Take a left at the yield sign and you are on 26 rd. I'm just over the hill on RH side. Big trees, tan/green buildings. We're going to plan to park in the field BEFORE the buildings.
Map/picture: http://www.kennedydiesel.com/docs/loyal_mod.jpg
Or: N44
