Results 1 to 2 of 2
Thread: Diablo WOW
    Apr 2005
    Loma Linda Ca USA
    Talking Diablo WOW
    Well I finally installed the Diablo after sitting around for a month. Have it set on #2. WOW what a differance unbeileable. Wow what else can I say. Reset my speedo for the tire size change went to the 265's the things dead on. Next week I well put my boost stick back on. Took it off to get the comp reflashed for new updates at GM. Got reid off the intake pop. boost before the BS and Diablo was 22. Now with the Diablo 26 solid. Can't want to see it with the BS on this ot to be real exciting. EEEEEEEEEHA I'm happy. OH yaeh one other thing my milage went up quite abit 18.1 mpg soo far can't wait to fill up again have never seen it that hi. JD
    05 D/A CC LB LT SRW 4X4 Dark Gray Metallic -- Amsoil 2 stage air filter -- Amsoil 15w40 Oil--Amsoil Dual Remote Bypass Oil Filter -- Banks Monster Exhaust -- Amp Research Power Steps -- Prodigy---XM Radio -- HiJacker 21K 5er Hitch -- Primo Spray Bed Liner -- 05 Grand Juction 4 slides 39ft 5er -- Honey Keep It Under 15,500 Please
    Quote Originally Posted by JD Diesel
    ......OH yaeh one other thing my milage went up quite abit 18.1 mpg soo far can't wait to fill up again have never seen it that hi. JD
    Don't get too excited about that mileage just yet. Enjoy the numbers for now, but you'll be dissapointed when you fill up. The programming makes your DIC lie to you. The programming forces the PCM to deliver more fuel than what it commands (the reason for more power), and the DIC is clueless. If you drive the same now, as you did before the programmer, you might see improved mileage. The reality is, most folks use the new found power, and mileage (as well as tires) suffers.
