Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Transmission (4L80E) First and Second Gear Only
    Feb 2006
    Southborough, MA
    Red face Transmission (4L80E) First and Second Gear Only
    Hello,
    This is my first Diesel and my first Chevy Truck.
    My transmission only has First and Second Gear Only (no reverse, third or OD). I bought it this way, please don't ask why - I get enough grief from my wife.
    I've done a lot of searching on the web and have found conflicting info on the root cause and what the fix would be.
    I don't now very much about transmissions but my gut tells me that it is more likely an electronic or hydraulic problem rather than a catostrophic mechanical failure. But maybe this is just wishful thinking and am in denial about the possibility of replacing a sun gear, sun ring, sun shell, sprag or some other part requiring a rebuild (or close to it).
    I bought the ATSG (Automatic Transmission Service Group) manual "THM 4L80-E" for this transmission ($25 download PDF).
    In the troubleshooting charts they call out this specific condition "FIRST AND SECOND GEAR ONLY"
    INSPECT COMPONENT FOR CAUSE
    Solenoid B (311)
    Stuck Off
    Loose Connector
    No Voltage to solenoid
    Solenoid o-ring failure
    no PCM signal to solenoid
    2-3 Shift Valve Stuck
    Quad Driver Module Failed
    Possible Codes:
    68 Overdrive Ratio
    81 QDM & Solenoid B Fault
    85 Undefined Ratio
    87 Solenoid B Stuck Off
    I was getting a code 87 and quickly (maybe hastily) went and replaced the 2-3 Shift Solenoid. This did not fix it.
    While I was in there I should have checked the voltages to check for loose connecter, no voltage to solenoid and/or no PCM signal to solenoid.
    I also should have checked the 2-3 Shift Valve
    Does anybody know if I should see voltages if the truck is not running, but the ignition is in the "on" position and I put it in reverse or 3rd?
    Any experiences that you can share would be appreciated. I'll post back with my results.
    Thanks!
    Paul
    P.S. I bought a B&M Automatic Transimssion Drain Plug Kit #80250 to make future transmission fluid changes less of a hassle - in my opinion balancing a tray of hot tranny oil over your chest or face should be avoided
    P.S.S. I may have posted this in the wrong forum.... should it go in the "2500HD/3500 HD Trucks & Drivetrain" forum?
    '95 K2500 Extended Cab
    Mods: Pine tree air freshener
    Current Status: Lawn Ornament
    Jan 2005
    I've OH'ed lots of slushboxes, but never a 4L80E.
    A guy that rents property from me has a 1994 with the exact symptoms your's has.
    We have not torn into it, yet, but from what I have been reading, the "no reverse" is a "red flag" for a "hard parts" failure, rather than an electrical or solenoid failure.
    Reverse is supposedly all mechanically selected by the manual valve, and (except for pressure control), shouldn't suffer from a 'puter, wiring, or solenoid problem. It is likely the problem is in the DIRECT clutch, or associated sprag.
    I'd be curious as to what you find out, if you get into yours in the near future, as it will be a while before the one we're dealing with gets checked out.
    Sep 2000
    Imperial (St. Louis), Missouri
    I had the same problem. No shift out of first till a very high rpm, then a slam-shift to second, and nothing else. My speedo went nuts as well.
    It turned out to be a faulty output shaft speed sensor. there are two shaft speed sensors, one for input, one for output, and the computer uses them to determine clutch slippage. if one dies, the computer sees it, and forces a 'limp-home' mode. I dont think it lights the SES when it happens.
    The sensors are like $40 at autozone, and its a 5 minute deal to change them.
    Tim
    Ford Owner.
    Music by Andrew Lloyd Weber. Lyrics by Andrew Dice Clay
    Feb 2006
    Southborough, MA
    Hi Tim,
    My symptoms are a little different - no slamming etc. It drives normally but without reverse and won't shift into 3rd. It does sound like the sensors could be the culprit.
    Did you have reverse?
    Paul
    16gaSxS is offline Moderator, Have Shotgun & dogs will travel
    May 2002
    Great Falls, MT
    I'm with Bob, I had a 2 gear and reverse ok problem it drove me nuts it was something electrical , poor connection or short the exact problem was never found after much work it just went away. If you have a electriconic problem you go 2 nd gear only as a default. You can work through your codes. There are a number of componets that are can be changed if you drop the pan. If you change them all out it will cost serveral hundred dollars. (been there done it). If you have a honest and good transmission sho they maybe able to help. A local sho the owner check mine and drove it twice and he told me it was the electronics. Good luck keep us posted maybe someone that know these trannies can help you more.
    221K miles and rolling.
    Diesel Page member #81
    Sep 2000
    Quote Originally Posted by danbenili
    Hi Tim,
    Paul
    Yeah, I did, now that you mention it...
    Still and all, its probably a good thing to take them out and at least check them. I checked resisiance through both of them and found them vastly different. I cant remember what the resistance of the good unit was.
    tim
    Ford Owner.
    I'm voting with BobND. Reverse is purely mechanical, so no reverse is a mechanical problem.
    First check for codes, but I'm betting you're in for some hard parts.
    (sorry...)
    Jul 2005
    IL
    Unhappy no reverse
    I would agree when we have one come in with no reverse we start by pulling the pan you will most likely find big pieces in the pan (NOT GOOD)
    reverse mean hard parts failure it take comb of clutchs working togeather to make reverse.
    I think its time for trip to trans shop or time to order a rebuild and install yourself, if it is a hard parts failure make sure you clean the lines out, I normally replace the coolers as there cheaper than the transmission to replace
    good luck keep us posted
    Feb 2006
    Southborough, MA
    Default Update-Valve Body Out
    Thanks for all the replies and suggestions. I now feel like I'm on a mission.
    I pulled the valve body out today. Transmission is still in truck.
    Tranny oil could use a change but still has a red appearance with no burnt smell. No metal chunks or slivers in pan, just small accumulation of "silt" on bottom of pan - gone with one wipe of the rag.
    Everything looks clean, no junk in the passageways. Looking up through to other areas of the transmissions - the gears that I can see all look good - nothing missing - sharp distinct edges.
    Looking at the "Powerflow Chart and Shift Solenoid Pattern". Looking at what reverse, 3rd and 4th(OD) have in common, is the "Direct Clutch"...
    I'd like to rule out the "First and Second Gear Only" Condition outlined in the ATSG manual as it points to rule out electronic malfunction prior to pulling everything apart (aside from the 2-3 Shift valve - which I checked and didn't appear to be stuck - pulled the roll pin, slid it out-bounced it against spring).
    I think the transmission electronics expect rpms on the input shaft before you can test, I tried with the system on, but engine offf and couldn't get voltages to change on solenoid's A and B.
    Anybody have tips on testing the electronic inputs to the solenoids? I tested the solenoids by putting juice to them and they "click".
    Thanks,
    Paul
    Jan 2005
    Be carefull randomly putting current to the tranny solenoids!
    I'm not sure about the 4L80E, but MANY transmission solenoids have a diode built-in for voltage spike suppression, and if you power up the solenoid with reverse polarity, you'll blow the diode open, or short it out.
    Oct 2003
    Huntington In
    Lightbulb
    I would now be looking very close at the Trans. wire harness for any sign's of damage if you have checked out what Cowracer said.
    95C3500.Ext.Cab 97 Cooling mods. DSG Gear-1.95 TDCO. Bilstein Shocks. Firestone Air Bags. FSD Cooler. Banks EX System. Egt,Boost & IAT Gauges. JK High Flow/pop Injectors. Turbo-Master. Max-E 2.0. Water/Alky Injection. Amsoil Dual Bypass. Baldwin filter. aFe Air filter, Air box & Turbo Mods. Power Service Product. Large Duels 235/85-16. Tool Box\'s & truck, 8200 lbs.
    Have you checked for DTC codes?
    Are you sure you have first? Default behavior is 2nd gear only, all solenoids off. If the PCM detects a solenoid fault during power up, it will default to 2nd gear only and set codes.
    Feb 2006
    Southborough, MA
    Default DTC Codes
    It shifts between 1st and 2nd - I've test this and verified in D and D1 and D2.
    Yes - Code 87 (I replaced this solenoid - which would point to a potential wire harness issue). I'm trying to figure out how to test the speed sensors.
    Oct 2003
    Huntington In
    Talking
    Hold in hand and run really Fast
    I suggest you try this:
    Clear the code and verify it is cleared.
    Start the engine and shut it down without engaging any gears. Check codes again. If you get 87 then the problem is definitely in the wiring or the power to the trans cicuit (or the solenoid). The fact that it only sets one code points to specifics to that solenoid.
    If no code, try again but just engage drive, but don't move. Check again.
    Lastly, try engaging reverse.
    Let us know what you find.
    Feb 2006
    Southborough, MA
    Default Clearing Codes
    I happened to run through this procedure after clearing codes (and verifying). I ran through the gears and checked the codes while in a stationary position. Still coming up with 12 12 12 i.e. no codes. I moved it to the garage in drive before pulling the valve body, but didn't check the codes after the move. How long would I need to run it to get codes? I was surprised that I didn't get the code 87 again after running through the gears. My guess is that the codes may not show up immediately i.e. you've got to drive it for x minutes before it will log some codes?
    Thanks,
    Paul
    Nov 2003
    COLORADO
    I've had the no reverse problem before... As said above your looking at hard parts most likely. In my case it was a broken low band. There were no warning signs and no debrie in the oil. I checked all the electrical and and changed the fluid to no avail.
    white '93 K2500 started it all..
    red '94 K3500 old faithful
    black '93 K3500 daily driver
    '83 G20 conversion van
    '74 C65 truck diesel conversion...
    [QUOTE=danbenili]I ran through the gears and checked the codes while in a stationary position.[quote]
    I assume you mean you ran the shifter through the range from 1 to OD. this will not engage any solenoids other than for first. I don't have the manuals anymore, so i don't remember which solenoid positions engage which gears. However, this seems to point to a problem with something other than the solenoid as it passes the self test which tests the elecrtrical part.
    Only long enough for the PCM to decide there is a problem; longer than the allowed shift time.
    If you didn't disconnect the batteries, the codes will still be there if they were set, although I'm thinking they probably weren't. Did you put it into reverse for any length of time during this process?
    Feb 2006
    Southborough, MA
    Yes I ran through all gears, including reverse with no codes being set - in a stationary position. I did not recheck codes after moving Truck (my bad) and I did disconnect battery before pulling the valve body out.
    I've signed up for at www.alldatadiy.com and have found some interesting troubleshooting info that should help eliminate any electrical stuff as the culprit.
    I think I'm in need of a GM shop manual for the Truck. I have a Chilton manual and it is severely lacking (IMO) and the alldata does not appear to have everything the shop manual would contain.
    Is the only source for the shop manual a dealer?
    Thanks!
    Paul
    Jan 2005
