Just FYI, the changes made should not have had a big impact on DIC readings, in fact, should be none at all...
Easy driving is key to higher milage. I have not done any highway only trips in my Express but I average 17.5 all the time. I keep speed under 70 on the highway and take off easy in town.
I would think 20 is possible on the highway is you keep it under 70. With the 6spd ally you guys in the 06's run maybe better
Let us all know how ur new tunes do. Why is your 05 for sale?Originally Posted by Kennedy
2007 GMC 2500 crew cab LBZ
6.6L duramax
Roof markers and XM radio
Rhino liner
Plat series nurf bars
Putco bed rails
Truxedo bed cover
edge juice W/ monitor temp uninstalled.
Hypertech stage 3
Are you happy getting 14-15 under normal driving conditions? U say your best milage is at 50-60 mph? That makes sense, its logic. People just dont drive that slow on the interstate in Mpls. I like to drive the speed limit 70 mph. If I do this I get between 9 and 11 mpg, pulling 5600 lbs. If I treat the pedal " like an egg shell" unloaded I can get 14 - 15 at 70 mph. If i slow it down to 60 mph ( only when I have to ) I can get 16 - 17 mpg. Do you guys really think these numbers are ok? I think not...
6.6L duramax
Rhino liner
Putco bed rails
Truxedo bed cover
Hypertech stage 3
I'm waiting for more feedback from my testers. I started another tester at the Rendezvous.Originally Posted by REDTRUCK05
I'm not really pressing to sell my 2005, but I put it up in anticipation of acquiring a 2006 LBZ.
I expect 19-20+ mpg from a single rear wheel truck driven at approx 60mph. My MPG drops at 70, but seems to drop less with tuning.
I'm the economy tune tester from the Rendezvous John was talking about above. Took a long trip this past week and averaged 20 mpg with expressway 70-75 mph, some highway at 55-60 mph, and a bit of city driving mixed in. Outside temps were 75-80 degrees.
Truck is a 2005 GMC Crew Cab 4x4 Duramax LLY/Allison. Presently 13,000 miles on the truck.
I want to take a trip of primarily 55-60mph highway driving to see what the tune is capable of.
I am also running Michelin LTX M/S 265-75-16 tires, which will lower your mileage a tad bit from the stock 245's.
At 70-75 mph EGT runs 600-650 degrees, and boost is about 3.5 lbs (on flat roads). At 55-60 mph EGT is 550-600 degrees and boost is less than 2 lbs. These readings are taken pre-turbo.
More to come....
Todd
TDP member #14
John - thanks for the reminder. I'm still out of state so there is more to come.
Initial reports thus far:
I weighed or entire rig at the local feed lot as we were leaving: 20500 lbs.
1st tank w/ DIC (no hand calcs at this time) - 13.6 mpg (the wife drove)
2nd tank w/ DIC - 15.8 mpg (I drove)
3rd tank w/DIC - 14.5 mpg (we both drove) This tank also had some some really steep grade coming through Wheeling, EV and then into PA south of Pittsburgh (all hills).
To come:
Hand calcs to compare against DIC (although I did notice less of a discrepancy with the 'fuel used' portion of the DIC).
Empty tank mileage with only me driving
Complete rundown of performance and mileage when I get back home
Just a quick note. Thanks.
Waldo
05 K3500 D/A Crew - Sport Red and sexy! JK exhaust and filtration, guages and EFI Live. What a blast!
71 K20 awaiting Cummins 12v swaps
For Sale: Deep Sump Trans Pan for a 4L80E
OK. Sorry for the wait. Taking 3 weeks off makes for alot of catching up to do.
Hand calcs are as follows:
Tank #1 - 13.55 mpg - DIC showed 13.6
Tank #2 - 13.65 mpg - DIC showed 15.8
Tank #3 - 12.84 mpg - DIC showed 14.5
Tank #4 - 22.36 mpg - DIC showed 23.6
Tank #5 - 16.16 mpg - DIC showed 18.3
Tank #6 - 13.15 mpg - DIC showed 13.9
Tank #7 - 12.29 mog - DIC showed 13.3
Tank #8 - 11.58 mpg - DIC showed 12.2
Tank #9 - 12.04 mpg - DIC showed 13.1
Again - I fill the truck the same way every time: fuel is at the lip and almost ready to spill out with the truck sitting as level as possible - engine not running.
I compared these figures to hand calcs from date of purchase. They are as follows:
Bone Stock - average of 13.91 mpg over ~10k
With JK's exhaust, Uni Filter and Mega filter upgrades - average of 13.72 over ~7k
Add EFI Live to above (only EGR fooled with - no added fuel or timing) - average of 15.9 over ~3k
Add JK's timing tune to above - average of 14.9 over ~5k (this is skewed as a majority of this is towing our horse trailer - only about 1500 miles without the trailer)
The shining star thus far: I hand calced a tank of fuel at 22.36 on a trip from Pittsburgh to Baltimore and back. This was my one chance to use an entire tank without my wife's heavy footed influence (which ever peddle she has her foot on, it goes to the floor). I only stopped once and that was to pull into my buddies driveway. I drove like a grandpa (no offense intended) and treated the throttle like an egg, never going above 55 mph, and coasting to stop signs and lights whenever possible. I know everyone doesn't drive this way normally, but I wanted to know what the truck was capable of. I usually drive this way when I just filled up the tank and am pissed about how much it just cost me. After a few hours, I'm back to my normal style that yields about 18.5-19.5 on the DIC. I usually get impatient with drivers that shouldn't be on the road, so there are a few full throttle runs and the occasional 80+ mph flights. With that said, I'm tickled to death that a 4dr dually can get this kind of mileage and have the power to play around every now and again.
Had I to do it over again, I would have done the same mods within the first 100 miles of ownership, and I still have a couple to go as of yet.
I keep some pretty decent records, so I would expect an update by the end of summer.
Waldo
I had a 02 LB7 2500HD W/Allison. Took a trip back to Missouri from Wyoming. From Cheyenne to Lincoln Ne. the truck got 20.7 MPG (hand calculated) running 75 the whole way. On the way back to Wy. the truck got 18.3. Here we go with uphill and downhill and wind. The wind always blows here and alway from West to east. I was very happy. The truck got consistent 15.5 to 16.5 running my day to day routes in town during the summer months. During the winter months it would get right at 14-15 MPG.
The new 06 LLY 3500 Dually, Allison does not do as well. I have not taken the trip back east since had this truck. But running my standard routes here in town the truck gets 13-14 in the summer and in the winter it drops to 12. I now pull a 18K fifth wheel with the truck and pull at 60-65 MPH average. Pull 175 miles to camp over three passes going as high as 9800ft. elevation and the average for the trip is 9.3 there and back. I use much more going than coming home. These were all bone stock truck numbers. I have now added 4" catback exhaust. But do not see much difference, maybe .5 MPG improvement at most. This truck does not do as well as the other one. But as stated before it is heavier and has the extra wheels. But she sure do run good!!
This is a great forum!!!! Keep up the good work guys.
2006 Chevy 3500 Big Dooley,CC, Duramax/6 Speed Allison, Victory Red. Pulling Jayco Talon ZX F36W Toy Hauler 5;er. 13,400 lbs dry and 18,000 GVWR
Wow 22+ on a dually! I never figured we'd see a dually cross 20mpg. I've been right around 20 with my single wheel, and recently hit 22mpg. Just need to "back it up" a few times...
Updated - over 25,000 miles now. 19 MPG seems to be working. Bone stock. 2500 HD CC.
http://home.columbus.rr.com/vfrket/Diesel/Diesel.xls
Note my calculated Miles Per Hour (miles for the tank divided by elapsed time (hours) from the from the DIC) to the far right. BTW, I still like my spreadsheet. There are few rows of data where I had to add a couple tanks together.
Kelly
Kelly T
John,
I agree with you. I never thought I would see it either.
Did you have the AC on? I've found that makes a pretty significant difference. Although I will have to admit, it's kind of hard to not run the AC when it's 80+ and humid. Ventshades work pretty good with the windows cracked and the vent on.
I also had the tires inflated to max rating in the rear due to the trailer towing.
I want to try running 235/85's and see if it makes a difference. I have a set off my 94 that's begging to be installed. I just need to use up the ones that are on it now. Just wish I didn't have to machine the Alcoa's to get em to fit.
I'm going to be making a run to Eagle River WI here soon. Hopefully I can back up that 20+ number.
Waldo
Kelly T:
I looked at you spreadsheet, and you seem to have a period where your were getting 16-17, and then back up near 19 average. Are these all long trip flatland driving - your average speed per engine hour is about same as mine, or maybe a bit higher.
That is pretty impressive mileage - what did you do different?
Bet I can do with careful driving over a tankful is about 18 US mpg.
However mine is a K3500 = 7000 lbs empty and 4wd, is your perhap 2wd, and less weight, which could make a difference?
2005 Chev K3500 SRW Dmax Allison Ext Long Box
Best I can attribute it to is crappy gas in the winter, bad road conditions (some time in 4wd just to commute to work), and maybe some more city driving. My 2500 HD is a 4wd. I live in central Ohio so now and then we get some winter. At the time I was disappointed too.
Behavior-wise - biggest thing is trying not to be hard on the gas in stop/go traffice trying to get out of Columbus when trying to reach the highway. That seems to be the killer on calc and indicated MPG quickest. Sometimes when sitting in traffic (red light, grid-lock) I'll shift to neutral (automatic) so the truck isn't pushing against the brakes. My driving has some hills on it, but not a lot.
I have no bed cover either. I'd like a "Undercover" and an Edge Juice w/Attitude (or maybe a visit to John Kennedy) to see how they play out from an economy viewpoint (and some pep when desired). And then a 4" exhaust (full). I don't do anything wild with air pressure - keep it at the top of the normal limit (50 psi). Not hauling a load too often - when I am it is an morotcycle or 4 wheeler and my milage gets better as it keeps air off the tailgate (or seems too).
2 cents,
Kelly
Kelly T
Hi guys
New here, love the forum so far.
I recently bought an '06 Chev Crew 1 ton SRW LB 4x4 LBZ. My first hand calculation of mileage running empty at average 70mph was 18.32 US MPG. My next was a long trip pulling my 26 foot holiday trailer (which my wife likes to load to the nuts) again at average 70 mph and I hand calculated 10.41 US MPG. Not quite as good as my old '93 Dodge Cummins, but then she couldn't pull that rig at 70 mph all the way, either. I am a mileage buff, too, so I will likely post more results as time passes. With fuel prices skyrocketing lately, good mileage is a big concern. I think a 2 mpg increase would be worth it to justify a "mod".
This "Economy Tune" for sale yet? What is involved and how much?
Need any Canadian testers???
I've got about 17,000 km on my truck now, and I've kept records for every fillup so far.
The tunes are available any time. There is a review by Todd Smith on this site.
best i've done is 20.1 mpg empty and 15 mpg pulling a 6800lb travel trailer
2016 LML 3500 D/A Black CC High Country , Towing a 29ft Big foot trailer
Recently took a long trip to the East Coast over Labor Day holiday about 1500 miles, 90% turnpike/expressway driving 60-70 mph, 10% city driving. Truck had 4 passengers, box full of luggage/cargo. I averaged 19.8 mpg hand calculated, DIC said 19.7 mpg average. I'm am running Kennedy's economy tune from the Rendezvous. And also running LT265 tires, speedo is accurate (verified with GPS). Had lots of driving in the rain and wind!!!!
TDP member #14
This "economy tune" sounds real good.
I think mine would have done about 17 -17.5 driving as you have described.
If true, at $3.00 per Gallon, you saved about $30 on this trip, and if you keep the truck for 200k you might save about $4000.
From what I saw on Kennedy's site, you need a spare ECM to load his tunes.
What was the procedure for you, and what did the whole thing cost???
