Hi All,
I'm now looking for tires to put on my new H2 rims. Ideally I'd like to stick with the stock width and height. I little taller is OK but definitely not more than an inch. If I have to go a little wider I will but again, I really don
Hi All,
Art Paltz
1999 Suburban K2500 6.5TD (stock)
2000 Undercover Dragster, 468 BBC, 7.74@173MPH, waiting on new 622 aluminum BBC to be finished.
1992 Tube Chassis Camaro, 468 BBC, 8.54@157MPH (SOLD)
1987 Buick Grand National, 11.8@114, pump gas (for sale)
1969 Camaro SS/RS 396-350HP, stock restoration, it never leaves the garage...
The 80 psi is for "E" rated tires. The factory steel rims for a 2500 6.5 burb are riveted being stronger than welded.
I suggest if you go w/D rated make sure it is rated for 3,000+ lbs @ 65psi, remember we are talking a 2500 burb here.
Thanks, I see that now. Seems all most of the tires that are 3000lbs are E rated.Originally Posted by DA BIG ONE
Art.
Art Paltz
Here is a really nice tire spec chart from the BFG website. (Its the address for the info and spec on BFG TA's)
http://www.bfgoodrichtires.com/asset...rain_ta_kd.pdf
Gives you pretty much everything you'd want to know about actual tire sizes, rim fitment, both weight rating, and actual tire weight capacity - which changes some dependent on tire size. For example - there are some "D" rated tires that will bear the same weight as an "E" rated tire - depending on size. Don't know if you can say that these ratings would be exactly the same for other company's tires - its just that this is a nice quick education on tire info.
\'95 \'Burb 2500 4WD, 3\" exhaust, Eagle Alloys, Heath Balance Flow and 21\" 9 blade fan plus driver cooling mods, Heath PMD Isolater, plus ISSPRO Pyro and boost gauges waiting to be installed - 199K miles and counting - Towing Moosenstein - the locked and loaded trail Jeepster Commando.
