Quoting From The Edge EZ Manual: "We recommend level 1 or 2 for towing applications. Only use level 2 if you are towing a light load. Level 3 should never be used while towing. Level 3 is a great overall driving level. When driven responsibly, and used with an EGT gauge, level 3 will not stress the stock engine or transmission as long as you are not towing."......Nuff said.
2005 Chevy 2500HD, CC, SB, 4X4, Duramax, ARE Topper, 60 gallon RDS toolbox/tank combo, Kennedy Headlight Booster, Isspro pyrometer and boost gauges, EGR Blocker, PCV Kit, Bilsteins, 265 Michelin MS-2, TTS Exhaust, pulling 35' Jayco travel trailer.
