Results 1 to 10 of 10
Thread: Massive White Smoke?
    Dec 2002
    Terre Haute IN
    Default Massive White Smoke?
    80 Olds Cutlass project. Bought a new pump and injectors hoping to cure my white smoke problem. No luck, still have TONS of white smoke! Starts fine, idles very rough, ~380PSI compression per cylinder, cold engine! No diesel rattle. Floored it won't make it above 3000RPMs.
    Timing chain?
    99 K2500 GMC Ext Cab, 6.5TD, Heath ECM reflash, TDC Offset -1.80, Bumped Optic, FSD Isolator, Turbo Master, KD 3.5" Exhaust, 4.10s and 33x11.50, Intercooler is next.
    98 Burb 350 1/2T/4l60/246/10Bolts - Wifes Ride
    80 Olds Cutlass 6.2/Studded/700R4/12Bolt 3.30s/IP=4544 Juiced by JK/Best MPG=30
    79 Olds Cutlass, 410ci/700R4 - Currently Restoring
    1992 Mitsubishi Eclipse Turbo, currently 12PSI max boost
    39 Chevy Rat Rod
    2004 Sportsman 600
    2002 Scrambler 500
    2007 Sportsman 90
    2003 Kazuma 50
    2001 XR50
    1990 Murry 46"
    43 Total pistons!
    Email= Dr.Diesel@gmail.com WA9SDJ
    Sounds like your timing is way retarded. Try advancing it about 1mm at a time. Your timing chain/sprockets could be very worn, causing the default timing marks to be retarded.
    Dec 2002
    Terre Haute IN
    I tried advancing the old pump as far as it would go, didn't help. I'll try this one and report back.
    And when I say smoke, IT SMOKES, i'm talking major smoke screen!
    39 Chevy Rat Rod
    2004 Sportsman 600
    2002 Scrambler 500
    2007 Sportsman 90
    2003 Kazuma 50
    2001 XR50
    1990 Murry 46"
    43 Total pistons!
    Dec 2002
    Terre Haute IN
    OK, I almost got excited! Pushed the pump to the drivers side to the max (probably 2-3mm)! First ~20 seconds of running no smoke, then started puffing again. Didn't seem as bad as before.
    And for the first time i heard rattle!
    Its got to be the chain?
    39 Chevy Rat Rod
    2004 Sportsman 600
    2002 Scrambler 500
    2007 Sportsman 90
    2003 Kazuma 50
    2001 XR50
    1990 Murry 46"
    43 Total pistons!
    How long has it run? Has it run long enough to get all the air out? If there is enough air in the pump and lines, it will smoke until it's bled. Air will retard the timing. Which way are you rotating the pump to advance it? Remember, the pump rotates opposite the crank/cam.
    Dec 2002
    Terre Haute IN
    The air is out, i have a clear tube on the return from the IP to "T". I am advancing the pump, pushing it towards the drivers side. I also have a pressure gauge post lift pump, ~10PSI at idle.
    39 Chevy Rat Rod
    2004 Sportsman 600
    2002 Scrambler 500
    2007 Sportsman 90
    2003 Kazuma 50
    2001 XR50
    1990 Murry 46"
    43 Total pistons!
    Sep 2001
    Lubbock TX, USA
    Hmm, Very familiar!
    OK, I tinkered inside of a 4911 pump trying to get the max governed speed above the 3600 RPM limit it was set for. Don't know what I messed up, but it did this same thing, ended up swapping out the injection pump.
    Engine would start, but wouldn't really idle at all and would die, wouldn't rev, and would just BELCH white smoke like no tomorrow, completly white, no grey, no black, WHITE like a cloud in the sky, but in my shop instead.
    I suspect a bad injection pump, or whatever is wrong with mine, still sitting on the shelf for a pump guy here in town to tinker with...
    Dec 2002
    Terre Haute IN
    Since this is the 2nd pump that has done this, I sure hope its not the pump!
    I guess i'm gonna have to tear it down and inspect the timing chain!
    I did fill with a fresh tank of fuel before this happened?
    39 Chevy Rat Rod
    2004 Sportsman 600
    2002 Scrambler 500
    2007 Sportsman 90
    2003 Kazuma 50
    2001 XR50
    1990 Murry 46"
    43 Total pistons!
    Dec 2002
    Terre Haute IN
    Fixed, the pump return lines was clogged!
    Any chance of pump damage because of this?
    39 Chevy Rat Rod
    2004 Sportsman 600
    2002 Scrambler 500
    2007 Sportsman 90
    2003 Kazuma 50
    2001 XR50
    1990 Murry 46"
    43 Total pistons!
    Aug 2006
    no i doubt it
    1989 GMC 3500 6.2L diesel
    1984 Chevy 1500 6.2L diesel (New Rebuild)
    1983 Chevy Blazer 6.2L Diesel
    1984 Chevy Suburban 6.2L Diesel
    1987 GMC Dump Truck 7.8 Liter Inline Six
    1973 Massy-Ferguson 245 3cyl perkins
