Results 1 to 7 of 7
Thread: Curb weight of a 94 Ex-Cab dually
    Tampa, FL
    Default Curb weight of a 94 Ex-Cab dually
    Guys, I'm trying to figure out if I need to upgrade my axles on my gooseneck car trailer to haul my 94 Dually. I'm close but if I can save some coin without changing them it'd be a plus. So I need to find out the curb weight a 94 Ex cab dually with a 6.5 TD and auto trans w/ 8 foot bed. If it's close to 5000# I may be able to keep the total weight under 7500#. Watcha think?
    Thanks
    David
    Oneton
    2002 3500HD Pewter/lt grey interior Crew Cab 4x4 LT Durmax/Allison
    I vote "not close." IIRC, my 95 LD K2500 ext cab SB cut the floor at about 6200. You've got heavier axles, frame, more tires and 18" more bed...
    I had a crew cab duall 4x4 and it tipped the scales at 7000#
    Jan 2003
    Boonville, IN
    Talking
    My truck weighs in just over 7000# with the usual stuff in the truck
    94 K3500 Dually 4x4, Avant 18:1, Girdled, ceramic coat pistons, Phaser gear drive, 98 cooling mods, PMD cooler, JK chip, JK 4" exhaust, Gauges
    Aug 2003
    Tucson, AZ
    My 1993 6.5TD, auto, extended cab, 2WD dually was weighed empty with half load of fuel at slightly over 6000#(6050# if I recall correctly).
    Bob
    Sep 2000
    Imperial (St. Louis), Missouri
    cc dually 2wd (with my fat a$$ in it) weight just at 6700
    Tim
    Ford Owner.
    Music by Andrew Lloyd Weber. Lyrics by Andrew Dice Clay
    Tampa, FL
    Thanks guys. It looks like I'll be adding the heavier leafs and axles. I'd rather be safe than have white knuckle ride up north.
    Thanks
    David
    Oneton
