Results 1 to 7 of 7
Thread: South Bend Clutch installed
    Nov 2003
    COLORADO
    Default South Bend Clutch installed
    Well, I finally saved my pennies and got a South Bend single mass flywheel with a single ceramic disk clutch. I started things Sunday night, figured I'd take it slow and easy so when the clutch got here I'd be ready to install. Over Sun and Mon night I got all the old stuff out and ended up with some free time which I devoted to waxing... That's another story though.
    Today the clutch arrived via UPS so around 2:30pm I started the reinstall. Got done and ready for the test drive by 5:00pm. There were no leaks and the SBC performs flawlessly so far. There is slight gear rollover noise at an idle, but if I bump it up to 800 via high idle it goes away.
    If you have a ZF6 equiped truck and are holding off on this because you don't think you're ready yet I'd recomend doing it. It's amazing what a difference a good clutch and flywheel make on driving enjoyment.
    I ended up replacing the slave cyl for $139, the trans/transfercase gasket+transfercase output seal for $60, and the clutch for $1187 delivered. So for a grand total of under $1400 I have the drivetrain from the engine back good to go for as long as I can drive the pickup for. Like I said before, Well worth it IMO!
    I got the clutch from John@ Dynadroitdiesel.com. I'd highly recommend John to anyone thinking about buying a clutch.
    white '93 K2500 started it all..
    red '94 K3500 old faithful
    black '93 K3500 daily driver
    '83 G20 conversion van
    '74 C65 truck diesel conversion...
    Nov 2000
    Hamilton, Montana USA
    You're not living up to your handle.....
    You need to change it to Diesel Genius!
    Have you dyno'ed the truck after the EFI live tuning?
    Chris
    1999 F-250 PowerStroke Crew Cab Short Box Lariat 4X4
    Fumoto, Turbo-Master, MBRP 4", Billet Triple Disc TC, HD TransGo Tugger, AIS, Triple Pod, Autometer Phantoms, SPDiesel Overboost Eliminator, SCT Tuned By Tadd @ Elite Diesel Performance 75/100/125 and DP-Tuner 80 Econo PCM, Sirius Radio...
    2006 Jeep Liberty CRD Sport 4X4
    Stock for now...
    My Gallery
    Nov 2003
    COLORADO
    Thanks TG! It's not very often someone says something nice to me.
    No dyno yet after EFIlive. I just started playing with it. With the stock clutch I couldn't do much HP tuning, but did get to play with a friends Ally equiped ride. Hopefully next spring I'll have some good tunes to dyno with. Have to build another 6.2 before I can play with EFI though...
    Loyal WI US
    Play with the idle speed at different RPM's until you find what runs the quietest/smoothest. We set JJGMC's dual disk equipped truck to 800 all the time and it seems pretty good. You could possibly get away with less though as the dual disk is quite different.
    Nov 2003
    COLORADO
    800 seems to be the magic number for mine as well... I'd like to hear what the new sprung hub double disk units are like.
    Loyal WI US
    With the loose "floater" it's pretty nasty IMHO. Especially when you push in the pedal. Sounds like a big putty knife is being dragged on a wheel. JJ doesn't mind it, and I guess it's a small price to pay for true holding power, but it sure doesn't compliment a sophisticated and refined truck...
    I'd like to hear Mac's dual disk. I guess he has the floater sprung to help eliminate this noise
    Nov 2003
    COLORADO
    I've been around a couple trucks with the dual disk and understand what you mean about the noise... That coupled with the rumoured transmission wear I didn't want anything to do with them.
