Results 1 to 20 of 43
Thread: 6.5 TD Highway Mileage Poll by GMC Hauler
    Aug 2005
    Alexandria, IN
    BE CAREFUL!!!
    I think that ECM programmer is quoting "Canadian MPG", which uses a different sized gallon that we us in the US (4.456L CA gallone versus the 3.785L "US gallon"). APPLES TO ORANGES comparison with his results. His results should read "20.4 to 21.1 US MPG" to be apples to apples, which is still great fuel economy but much more realistic than 25MPG!!!!
    Please also note that he quotes the odometer reading in "kms", which is an additional clue...
    1994 Chevrolet K3500HD; Crew Cab; 6.5TD Vin F; 5 speed manual; 201K miles, Homemade WG control...
    Oct 2003
    Maine
    Quote Originally Posted by gherrell
    BE CAREFUL!!!
    Good catch...
    Gove me a few days to make some adjustments..
    Those of you who post in KM, please make it obvious to me so i don't miss it.
    BE CAREFUL!!!
    Actually it's 1.201 of the US Gallon. 20.8 US MPG.
    kms to miles is 1.62 ratio
    I could confuse you further with litres consumed per 100kms....
    Lyndon
    www.ecmprogrammer.com
    Westers Garage.
    Aug 2005
    Alexandria, IN
    Quote Originally Posted by ECMProgrammer
    Lyndon
    Westers Garage.
    Well, your original post specified a RANGE of 24 to 26 MPG (Imp). Which, if converted to US gallons, would be 19.98 to 21.64 MPG (US). And trust me, you would not confuse ME with L/100km's. If you really wanted to confuse people, then give your fuel economy in furlongs/firkin (*0.88888889)
    Dec 2006
    Absarokee, Montana
    Default Mileage Survey
    1. 93 GMC 6.5 Turbo Diesel, extend cab, long bed pickup.
    2. Sierra 2500HD
    3. 2x4
    4. 2
    5. 2
    6. No
    7. 42 gal.
    8. ?
    9. 235/85 R16 10 ply Cooper Discovery.
    10. Mud and Snow.
    11. ?
    12. ?
    13. ?
    14. 5 speed manual transmission.
    15. ?
    16. ?
    17. ?
    18. ?
    19. ?
    20. Stock
    21. ?
    22. ?
    23. 3" straight pipe.
    24. ?
    25. ?
    26. Natural oil, Shell Rotella.
    27. 22 m/gal.
    28. Fall/Winter.
    29. 70K.
    Sep 2006
    Brooker, FL
    Since I've repowered StaRV II with a new AMG engine, things have changed, so I'm revising. Old numbers in italics:
    Everybody's got something so, so, NORMAL...
    1. '94 Barth ["What the HELL is that?"] 28' Breakaway Class A motorhome
    2. 8500? (I dunno, it has a GVW of 18K lbs.)
    3. 4x6
    4. 1 (As if there's anything else as an option)
    5. 1
    6. Injector cleaner and lubricity additive for USLD
    7. 40
    8. Dana 80 4.53 (I think - Mag-Hytec cover installed)
    9. 8x19.5
    10. Mixed
    11. Gear vendor? Nope - no room and unnecessary
    12. Boost control: Non-wastegated turbo - 12 psig max (Purely Stock)
    13. Same as 12.
    14. Automatic Trans 4L80E (Mag-HyTec pan installed)
    15. Thermostat: 2x180F stock with new mill (Kennedy Diesel kit installed)
    16. N/A - DB-2
    17. Timing Gear: Phazer (N)
    18. Intercooled: N
    19. Mist injection: N/A
    20. Air filter: Stock Wix, but this diesel pusher has far less restrictions - "Snorkle" is 4"
    21. Non-EGR
    22. GM Turbo Style: Peninsular Diesel Supplied
    23. Exhaust: 4" Turbo to ground
    24. TDC offset set to : Stock
    25. Hi-Pop Injectors (Stock injectors)
    26. Synthetic oil: N Total waste of money (I'm a former fuels and lube engineer)
    27. Highway mileage: 11.0+ mpg (9.8 mpg)
    28. When mileage data was obtained: Winter (Summer)
    29. Approx miles on vehicle: 56,400 (52,500)
