Another thought
If c-clip that retains stub axle to carrier is worn (not holding) the stub axle can slide in and out of carrier then wobble, vibrate and at extreme angles come completely out (especially when tq bar key is overtightened for x-tra lift) of frt/diff resulting in major failure of steering/braking control.
