Perhaps
I'm guessing there is a vehcle speed sensor buffer (VSSB) needed in the circuit and calibrated to your gears, tire diameter, and such, but not sure if PCS even needs the vssb.
The vendor "PCS" should be able to help w/issues such as yours
