I went through quite a performance with this problem and I really hate walking. To go along with this my tach started to act up although all the scantools said the senders were giving the right signal. The dealer mechanic said I needed a new instrument cluster. As it turned out we noticed that the charging rate seemed low so changed the alt. This cured the tach problem . Not sure why but one should not look a gift horse in the mouth.Didn't cure the no start/stall. I changed the ignition switch and have not had a problem since.I remote mounted the fuel driver several years ago but changed it and the pump at this time. The pump was getting close to expected life anyway.
Amsoil Dual Bypass. Baldwin filter. aFe Air filter,
