Results 1 to 10 of 10
Thread: CONTEST: Guess my GCVW!
    Default CONTEST: Guess my GCVW!
    I took this load of galvanized sheet metal, knowing that it was on the 'heavy side'. Wanted to see what the true max capacity of the C4500 was - regardless of the manufacturer's rating. This was all the way there.
    This load went from Minneapolis to Des Moines. Braking and handling were fine - outside rear dual would contact a smooth outside bed rail on major bumps, nothing harmful to the tires.
    Closest guess wins an MRE logo baseball hat. (Woo-hoo!)
    Knoxville,Tennessee
    17,300 on on the road loaded with you and fuel
    -Patrick Henry
    A5150nut
    2006 K3500 D/A
    94 6.5 4x4 5spd Sold
    Considering you say "regardless of the manufacturer's rating" I'm going to say 19,850...
    Diesel Page Member #2423
    Maplesville, AL - Home Base
    Ed
    Ed
    KM4STL
    Sep 2003
    Feeniks, Aridzona
    20,750 is my guess.
    Sep 2001
    Mesa, AZ
    19,500lb my guess
    1995 Suburban K2500 6.5TD 3.73's Innercooled, Updated cooling, Banks 3" exhaust no gizzards in the kittie. Pyro/Boost/Trans temp. Transgo HD valvebody kit.
    2002 2500HD, CC, LB, 4X4,California Truck, Federal Emissions Front pipe, Plugged recirculator, modified air box(Per Kennedy's page) 6" RCD lift, 35" tires.
    Jul 2003
    Allentown, PA
    my guess: 19,120
    Ed Hale gets the hat...he was close...
    Thank you very much Mark. Lucky guess.
    Ed
    KM4STL
    No problem - shoot me a PM with your mailing address. It may be a week or two, I am out and having another batch made, they should be done in 7-10 days max.
