Results 1 to 4 of 4
Thread: 6.5 injector pop psi ?
    Apr 2007
    ARIZONA
    Default 6.5 injector pop psi ?
    What is the 6.5l injector pop psi/bar for a ?
    1.stock N/A injector?
    2.stock turbo injector?
    3.high pop N/A injector?
    4.high pop turbo injector?
    5.marine N/A injector?
    6.marine turbo injector?
    7.marine high pop N/A injector?
    8.marine high pop turbo injector?
    Would like "exact" numbers not "around" but if you have some pop pressures that work good, post them along with how good they worked. I think this thread will help others not just me! Thanks
    Mar 2007
    Woodstock GA
    These are from a friend who works in an IP shop.
    Injector Numbers
    BOSCH
    New #-----------Body #----Reman----Tip-----Pressure---Application
    0432217081....0430211051...NA50X...0SD248....126 bar......6.2L 1982
    ???????????.....0430211058...NA52X...0SD253....126 bar......6.2L Long body
    0432217092....0430211054...NA51X...0SD253....126 bar......6.2L Short body
    0432217229....0430211054....??????...0SD304....126 bar......6.5L N.A.
    0432217251....0430211054....??????...0SD304....142 bar......6.5L Turbo
    0432217255....0430211054....??????...0SD311....150 bar......6.5L TD Marine
    0432217275....0430211097....??????...OSD304....126 bar......6.5L N.A.
    0432217276....0430211097....NA56X...0SD304....142 bar......6.5L Turbo
    "bar" is equal to 1 atmosphere - multiply 14.7psia by the number on each line to determine actual injection pressure
    Delphi Injectors
    6703803---6.5 T.D.
    6703802---6.5 N.A.
    6703801---6.2 "Van" Short fine thread
    6704001---6.2 Long fine thread.
    Standyne Injectors (New)
    37818 10233973 6.5L T.D. same as 0432217276 6703803
    38272 10233972 6.5L N.A. same as 0432217275 6703802
    * Info has not been verified but is believed to be accurate till somebody proves otherwise.
    Don
    Apr 2007
    ARIZONA
    Thankyou for your input, More than I thought I would ever get from just one person, Thanks again very helpful.
    Mar 2007
    Woodstock GA
    I credit that data to DieselPro on another site. He's excellent with info.
    Don
