Results 1 to 5 of 5
Thread: Received First Oil Analysis Today
    Aug 2001
    Maryland
    Default Received First Oil Analysis Today
    2001 GMC Sierra 106,583 miles when tested. 17,082 on oil w/three filters when collected and tested. I’ve used AMSOIL ever since I purchased the truck with 4400 miles. Here are the results: NORMAL (as reported)
    IRON 8
    CHROMIUM 0
    LEAD 17
    COPPER 131
    TIN 0
    ALUMINUM 3
    NICKLE 0
    SILVER 1
    SILICON 12
    BORON 1
    SODIUM 0
    MAGNESIUM 16
    CALCIUM 3917
    BARIUM 0
    PHOSPHORUS 1135
    ZINK 1426
    MOLYBENUM 0
    TITANIUM 0
    VANDIUM 0
    POTASSIUM 0
    FUEL (%vol) <1
    VIS @40c cSt N/A
    VIS @100c cSt 13.24
    WATER (%vol) 0
    SOOT/SOLIDS (%wt) 0.1
    COOLANT: NO
    TBN 7.01
    OXID 2.0
    NITR 4.0
    F-SOOT 0.05
    The test indicated the copper was high and possibly from lube oil cooler.
    How does this look to the experts out there?
    2001 GMC 2500HD CREW CAB 4X4 D/A Lucerix X-Mount, Fumoto Valve, 100% Amsoil,
    Leer High Rise Cap
    Discover America in a D/A!
    2003 Cougar 30' T/T SOLD!
    JD 2210
    1987 Corvette
    Member #4307
    Check here for a discussion about copper values in an engine oil analysis.
    Aug 2001
    Maryland
    Thanks MorePower...I read the other thread and it's my understanding that this high copper content is most likley oil cooler related. Is my (131) high reading any indication of potential failure?
    Leer High Rise Cap
    JD 2210
    1987 Corvette
    Member #4307
    Owego, NY
    Quote Originally Posted by Luis View Post
    ... Is my (131) high reading any indication of potential failure?
    Luis,
    Your other wear metals seem normal and within the range of other Duramax UOA’s posted over at BobIsTheOilGuy.com. The higher numbers may be just due to the 17kmi extended drain interval … the longer you run the oil the higher the concentration ... You might try pulling a sample at 7.5k to see how it compares .. For reference here’s a recent UOA report from my 03 ..
    2003 Chevy Duramax Diesel, Baldwin B1441 Oil Filter, AC A1618C Air Filter, Oil Guard Bypass Filter
    Test Date: 10/5/07
    Oil Grade: 15W40
    Oil Type: Chevron Delo 400 CI-4
    LAB: PMSI - AVlube
    Miles on Unit: 74,810
    Miles on Oil: 6,611
    Iron: 4
    Chromium: 0
    Lead: 5
    Copper: 5
    Tin : 2
    Aluminum: 2
    Nickel: 0
    Silver: 0
    Silicon: 5
    Boron: 104
    Sodium: 2
    Potassium: 6
    Magnesium: 207
    Calcium: 2,613
    Barium:
    Phosphorus: 1,206
    Zinc: 1,555
    Moly: 218
    Fuel: Acceptable (0-3)
    Water: <0.1
    Glycol: Neg
    Visc-100ccST: 13.8
    TBN: 6.5
    Soot: <0.1
    Oxidation: 11.00
    Nitration: 5.00
    Oil was topped off with 16oz of Power Service Diesel Lube Oil Extender near the end of the OCI
    This is my first OCI with DELO 400 since the truck was new and it’s the best UOA to date … (click on UOA History in my signature) The truck now has old stock M1 T&SUV (5w40) for the winter .. If I didn’t live in the cold northeast I would run the DELO 400 all year round..
    Bill
    98 K3500 6.5,SOLD
    Aug 2001
    Maryland
    JB...thanks for the reply...I will pull the sample after 7.5k and get a comparison. Thanks everyone
    Leer High Rise Cap
    JD 2210
    1987 Corvette
    Member #4307
