Results 1 to 17 of 17
Thread: ECM Computer Upgrade - HEATH or SS DIESEL
    Aug 2007
    Sacramento, California
    Default ECM Computer Upgrade - HEATH or SS DIESEL
    Thinking about upgrading the ECM on my 1996 6.5l Suburban.
    However, I am not sure which would be the better option for me:
    - The SS DIESEL SUPPLY ssd-404:
    "Performance Upgraded ECM's (computer) for all 6.5 Turbo Diesels 1996-2005 model years. This ECM performs better then any competitors ECM. Specific to your application, will adjust fuel rate, injection timing, boost pressure, tranny pressure and shift points for maximum power and performance. Whether towing a heavy trailer, or just for blowing off Fords, this ECM will add raw power.
    2 versions available at the same price. 40HP 80ft/lbs of torque, or 80HP 160 ft/lbs of torque. Even better results are seen with the addition of a #9 Performance Resistor.
    The 80HP version requires a modified exhaust such as our 4" system, and full gauges, EGT and boost."
    - The HEATH DIESEL HDP1448 (Which includes the Turbo Master Boost Control):
    "Your 6.5 is a great engine design, that in factory tune, is far from being optimized. The Max-E-Tork PCM, Turbo-Master boost control and PMD Isolator are designed to work together to transform your 6.5 into a very respectable performer with strong towing power. Improved combustion efficiency results in increased fuel economy, too. Adds 65 hp and 130 lbft torque at the flywheel."
    I am currently running with a Performance Air Intake Kit, the 4" inch Exhaust System from Jerry Jardine, Pinnacle Power Exhaust is in the garage waiting to be installed and I will also get the Gauges for EGT and Boost mounted.
    - Looking for the following input please:
    1.) What do I use? SS DIESEL or HEATH?
    2.) Are there other ones out there which might be better?
    3.) Do I really need a Transmission Temperature Gauge as well?
    Thanks in advance.
    '96 Chevy Suburban LT 2500, 4x4, 6.5L Turbo Diesel, 4.10 Rear, 175K miles
    *** Towing 26' ft. Travel Trailer (6,165 lbs DRY) ***
    - aFe Stage 2 Performance Air Intake Kit
    - 4" inch Jerry Jardine, PINNACLE POWER EXHAUST, 5" inch Chrome Tip
    - 2-1/2" inch Crossover Pipe, mandrel bent
    - KENNEDY remote mounted PMD/FSD Cooler Package, DTech PMD
    - AUTOMETER Triple Gauge Pillar (Boost, EGT/Pyro, Trans. Temp.)
    - HEATH Turbo-Master
    - HEATH Max-E-Tork PCM
    - PRODIGY Brake Controller
    - BILSTEIN Shocks
    - Forged WELD RACING Rims
    - 265x75 R16 BF GOODRICH All-Terrain T/A's
    This thread ought to be fun!
    I've heard good things about the above vendors, and I've heard good things about BD & Kennedy as well. If you know what your truck dynos at now, you could ask each vendor what their chip will do for you. It would be fun to put them all on the dyno....
    Depending on whether or how much you tow, you may need a trans temp gauge.
    Dec 2002
    Terre Haute IN
    There are only two that truly know the 6.5/6.2. Give kennedydiesel.com or heathdiesel.com a call, they will help you. You cannot get 80HP from a chip for the 6.5, bogus claims IMHO......
    99 K2500 GMC Ext Cab, 6.5TD, Heath ECM reflash, TDC Offset -1.80, Bumped Optic, FSD Isolator, Turbo Master, KD 3.5" Exhaust, 4.10s and 33x11.50, Intercooler is next.
    98 Burb 350 1/2T/4l60/246/10Bolts - Wifes Ride
    80 Olds Cutlass 6.2/Studded/700R4/12Bolt 3.30s/IP=4544 Juiced by JK/Best MPG=30
    79 Olds Cutlass, 410ci/700R4 - Currently Restoring
    1992 Mitsubishi Eclipse Turbo, currently 12PSI max boost
    39 Chevy Rat Rod
    2004 Sportsman 600
    2002 Scrambler 500
    2007 Sportsman 90
    2003 Kazuma 50
    2001 XR50
    1990 Murry 46"
    43 Total pistons!
    Email= Dr.Diesel@gmail.com WA9SDJ
    Jul 2003
    Allentown, PA
    Ditto the above. Also, try using the search engine - you'll find this topic has come up many, many times. Seek and you shall find...
    Nov 2003
    Davenport Florida
    I think either Mr Heath or Mr Kennedy are the only two PROVEN options for these trucks. I prefer the simplicity of the turbomaster design, which I installed first, along with Mr Kennedy's exhaust. Later I added the MAX-E-Torq, and the truck came alive. Gauges are a MUST, trans temp if you tow. Also, synthetic trans fluid will take MUCH higher temps and not break down. I use Amsoil and have been amazed how clean the fluid stays- not darkening from higher temps. In my mud truck I often see trans temps at 250, which is when I usually take a break and let it cool. 3 plus years of playing, and the fluid is still nice and red, and smells like new.
    email rfkjr@juno.com
    07 2500HD C/C LBZ 248k
    Aug 2007
    Thank you Scooby
    - So, are you saying that the Max E-Torque upgrade from Heath is good, is the way to go?
    - Any issues with getting the core charge back after sending your stock ECM back to Heath?
    Thanks everyone else for your input as well
    Thanks.
    - BILSTEIN Shocks
    Oct 2007
    Gridley, CA
    Default Heath Diesel
    I have worked with Heath Diesel quite a bit and have never had any problems with getting a core deposit back. I did my injectors this last may and returned a rented injector socket and they credited my credit card pretty quickly after returning the socket. They really know what they are doing up there. I have bought a turbo master, lift pump, and injectors from them and have been happy with all of them. When i finally make the purchase of an eprom it will definitely be from Heath.
    Heath Diesel actually does a lot of road testing their products in the mountains up in Ellensburg, WA. They have some pretty steep and long grades to test the products. Their products actually do what they say they do.
    94 GMC 2500 HD
    Ext Cab, Long bed
    6.5TD, Vin F, 4L80E, 3.73 gears
    Pinnacle 4" Exhaust
    Heath Diesel Turbomaster
    172,000 miles
    Sep 2000
    Imperial (St. Louis), Missouri
    I have a heath chip (pre v2.0) and I like it. I would buy it again. as a matter of fact, I need to get off my tuckus and get the 2.0 chip.
    That being said, I would not hesitate for a second to get the kennedy chip either. I probably woudn't get a chip from SS, even though I would buy anything else from them.
    The main diff between Kennedy and Heath is boost control. Kennedy uses the stock vacuum system to run the wastegate and he claims it allows tighter control.
    Heath chip allow the use of a mechanical wastegate control (which he also sells) and thats what I got. It allowed me to totally scrap the problematic vacuum system.
    either way its money well spent. BUT GET GAUGES NEXT. Tranny temp is good to have but not critical. Boost is more important still. but EGT gauge is critical.
    Tim
    Ford Owner.
    Music by Andrew Lloyd Weber. Lyrics by Andrew Dice Clay
    Here's a look at the HP/Tq data produced by a G-Tech Pro RR:
    1996 6.5TD GMC Suburban 4WD, heavy-duty VIN code F
    Owner Roger Story
    Heath Diesel Max-E-Tork
    PMD Isolator
    Turbo-Master set to 13.5 lbs boost
    Aug 2006
    Are the first 2 runs with the chip and the second 2 are without?
    Nov 2006
    Kelowna, BC
    Default Performance Parts
    I can't say which is better for the Performance Packs. However from what I have read, it seems that a lot of the horsepower upgrades that are offered are not completely accurate. I have read opinions that presented that front on here enough that I talked a friend out of buying a "90HP/170TQ" Chip. Apparently the new computer would increase horsepower by resetting parameters alone, no cooling or exhaust needed. The dealers was a parts place in BC. As far as tech support, SS and Kennedy have been the only two that have even responded to questions. Kennedy gave me a list of options for power w/reliability for the price range I had in mind. SS had quick response and good customer support for installing items sold, as well as chepaer than local prices.
    Nov 2006
    Kelowna, BC
    Default Power Upgrades
    Just as another tip. If the first post that I did on here is looked at, it is rather laughable. I came to TDP and posted looking for help to build a 350+HP engine for cheap. In the discussion that followed,lol, I figured out what my limits where fairly quickly and have been following the upgrades of guys like RJ. Figure the best way to learn is to follow the guys who are doing it and posting on here. The info I have learned on diesels since I joined TDP has been quite a bit. Best thing to do, ask the veterans 6.5TD drivers here.
    The above data image was from a CD folder labeled "Perf PMD, Perf computer, turbo master 13.5 max". The four runs were consecutive, without time to change much. If I were to speculate, I'd say the slower runs were warmups...
    The following data image was from a CD folder labeled "Totally Stock", and appears to be time-stamped a couple hours earlier in the day. Roger might have more input.
    May 2007
    Lagrange,Ohio
    Default ECM upgrade
    I have ss diesels 80hp ECM made a huge power increase. It's like having a new truck. It was simple to install great customer service. Had no problems with returning the core. I am very happy with this set up.
    2000 Chevy C/K 3500 crew cab srw 8' bed & cap,
    4" exhaust, 3" down pipe, K&N air filter, modified air box, relocated PMD on custom heatsink, #9 resistor, 2.5" stainless crossover, SSdiesel 80hp reflash ECM, EGT and boost guages, 3" body lift, 7.5' meyers poly plow
    Ask either if they do their tuning in house. I already know the answer...
    Dec 2002
    Terre Haute IN
    Speaking of, can we talk you into posting some of the Dyno graphs?
    39 Chevy Rat Rod
    2004 Sportsman 600
    2002 Scrambler 500
    2007 Sportsman 90
    2003 Kazuma 50
    2001 XR50
    1990 Murry 46"
    43 Total pistons!
    Since this thread is about Heath & SS, 6.5 dyno runs involving other vendor products might be more appropriately posted in This Thread in the 6.2/6.5 Tech forum, which is for any or all 6.2/6.5 dyno data.
