Hello all,
how much power would the 04 duramax with a 5spd have? is it recommended that i should use any power adders?
thank you in advance for your help,
Don Cannon
Hello all,
Don Cannon
87 c2500 6.2 turbo (boost @15 lbs),4911 pump, 6.5 injectors, thm400, 4.10 rear, newly dually, coming nv4500, intercooler, got a used engine suppose to be 50,000 miles
Don,
The early 2004 models were equipped with a 300 hp LB7. The late 2004 models were equipped with a 310 hp LLY. If you're not sure whether you have an LB7 or LLY, look at the eighth digit in the VIN. The LB7 was a #1 and the LLY was a #2.
There's a wide range of options for power adders, from plug-in modules to handheld programmers to ECM programs. Check the Product Reviews page for some ideas.
Contact Me
Content Web Site
Photo Album
TDP Youtube Channel - New!
thanks Jim
we went to see it and we both (wife and I) thought that the truck had too many miles although it had the 300hp engine.
thanks again,
Don
I have had a LB7, LLY with edge stuff on it , now I have a LBZ with a custom live EFI tune by Kennedy diesel. The EFI tune is much nicer to drive then the edge stuff , it pulls harder down low , improved fuel economy empty and towing . I would say this is the best option I have used to date. Dont put more then 70 hp more then stock threw a stock trans and it will live a long time , it you tow heavy you may want to back the power down to 40~50 hp added . Live EFI has the ability to do a few differnt programs in one ECM and change the tune on the fly with a in cab switch .
93 c-2500 6.5td,96 6.5td x cab,01 GMC lb7 Xcab ,2004 lly crew cab ,2006 lbz crew cab,honda CBR1100xx,2003 polaris prox 700 , 2001 31' holiday rambler 10K lbs house on wheels!
