Anybody find a good place to mount the antenna? I'm wondering if the bracket I used on earlier models can be modified to fit the 07/08s.
2007.5 2500HD 4x4 LMM, 1LT, crew cab, blue granite metallic, XM radio, TT mirrors, accent bed cover, GM step bars, 2003 Harley Deuce, 2005 Roadmaster Campmaster 26' RV toy hauler.
Hello,
I had a hole drilled just about 2" in front of my 3rd brake light for my 2m/440 antenna. The antenna wire is routed above the headliner to my A-pillar and then down behind the dashboard. Looks clean and works well....
Jim M.
'05 2500HD D/A CC SB 4x4 Silver LS ~65,000+ mi.![]()
Isspro EGT (pre-turbo) & Boost analog guages; 4" Magnaflow exhaust; Superchips programmer; Uni-Foam Air Filter; Boost stick w/ext.; Amsoil Lubrication products; Aux. fuel filter (Post OEM); FilterMags on oil, fuel, and trans; Bilstein shocks; Amsoil Dual Remote oil bypass; 60 gal. In-bed RDS Aux. fuel tank; Prodigy electric brake controller; VR3 Color Back-up Camera System, Battery tender
'10 Coachmen FW 35RLDS ~35', 11k lbs.(loaded)
As Jim pointed out for his on the roof is a good location. If no holes drilled is the choice then look at fender brackets (only small holes on inside of fender) and a good quality anti. Or if you are inclined to installing headache rack and box rails then a larger number of options are open to you. On my rig (79 dooly 4x4) I run two anti on the front fenders (commercial and cell) on the headache rack-three--2m/uhf; atas120(hf-2m/uhf); 80m) and a mag mount in the center of the roof for aprs(automatic positioning radio system {gps}). The Truck is a rolling porcupine.![]()
1985 K1500-sold
79 dually 4x4-soon to have modified 6.2/6.5l turbo
1996 shortbox-extended cab 2WD 1500 6.5L
