Results 1 to 6 of 6
Thread: Optimizer 6500
    Sep 2003
    Kalamazoo, Michigan
    Question Optimizer 6500
    Is this engine now available to the gneral public? Any field testing? results of installing them in our Chevy trucks?
    2004 2500HD LT Duramax LLY+Allison 2WD Extended Cab SB
    Cooper LTX265/75R16 tires
    Email vernj4@juno.com
    The 6500 is available and will directly bolt in and go right to work.
    AMG/GEP has done the testing and such as these engines for the HMMWV
    The engine can be purchased as a complete long block.
    Jun 2002
    Nederland- Schoonebeek
    Question
    Any news yet about the newest version from the 6500?
    Chevy Nova sedan 1977
    6.5 HD diesel/ 4L80e
    Gear drive timing set
    Ram air, E.P.S. stainless steel exhaust
    2.73 axle ratio/ 205-65-R15 tires
    new projeckt: Dodge W200 with Detroit 6V-92
    Jim (More Power) can bring you up to speed on any new stuff on these.
    Drop him a PM
    Apr 2004
    Palm Beach, Florida
    Thumbs up Try Diesel Page Advertiser
    They have 2 versions over the road hi-compression and marine low-compression
    http://www.peninsularengine.com/
    Sep 2006
    Brooker, FL
    When I bought my Peninsular AMG last year I was told all their engines come with 18.1:1 pistons, but then it could have been in context of my getting one for the motorhome. At the time the web site didn't show the higher-perfromance engines, so maybe that's changed.
