4x4 had Leaf Springs
I'm guessing you have upper and lower control arms being that you have no 4x4, all the 4x4's of that era were leaf spring hung.
You can install lots of different frt/differentials using the coil spring setup you already have, just decide which side the t-case will be dropped, find the diff you want, then use rear stay arms to hold diff in vehicle along w/adjustable panhard assembly.
One member used coil spring setup and has his project on display in the conversion forum. http://www.thedieselpageforums.com/t...ad.php?t=23569
Good luck!
Reason: add content
