Thread: 454 78 G30 van to 6.5 mech injection
    Default 454 78 G30 van to 6.5 mech injection
    Looking to put a 6.5 in a 78 G30 1 ton dually van chassis (motorhome). My thought is this should be fairly straight forward. My donor is a 93 K2500 complete with trans. Motorhome is a 454 with a TH400. Goal is to tow my 28ft race trailer behind the 22ft coach.
    Do I need a different torque convertor or is the big block TC the same? (if I use the TH400). Chassis will already be a hydro boost. The only snag I see is turbo location.....will I need a van turbo and manifold?
    Any input welcome!
    May 2005
    SE Wisconsin
    You will need a diesel torque converter and a diesel governor.
    1997 GMC Savana - 6.5 TD
    1967 Jeepster - Stock
    1986 Jeep CJ7 - Stock
    Jul 2005
    Greenville, Michigan
    Default 454 Convert to 6.5
    Just wondering how you came out. Would like to do the same convertion on a motor home
