 cylinder heads
 cylinder heads
					I have been using CCH for at least 4 years now one set is 5 years old was the test set we used  that truck was still running strong when I sold the truck 2 months ago.
Robyn spoke of Frito Lay using these that is correct I was involved in the decision to try these heads and I was also the person that installed the first set we used in are area.
The truck we installed them on had 126k on it it had broken a belt and the driver drove it 15 miles or more on interstate and cooked the engine he only noticed there was a problem when he went to get on the ramp no power steering and then noticed temp was pegged when he stopped then the steam came out. I had reinstalled the belt and refilled with coolant the truck drank coolant driver called after 5 days told me he used 6 gallon of coolant in 5days. after test found what I figured was blowing head gasket (hope that was all) pull heads found bad head gasket, then flipped the heads over and the cracks in the heads looked like spider webs. You could easily tell these heads where trashed, I was out of stock on new GM/GEP heads.
I had seen an add for CCH so after calling them asking all the same question Robyn had asked and some finical question regarding there company, myself and 6 or 7 other company people had a conference call talked over the pro and cons and them being made in china did come up we decided to try a set on this truck as it would cost us less for 2 heads then one from GM and we where not sure if this engine was going to last along time anyway. So I ordered a set of heads they overnighted them to me at no extra charge (good sales tactic to get my large fleet business) was very impressed with what they sent me. Installed them truck never missed a beat the rest of its life, its even lost the belt again when alt locked up at 188K miles different drive he noticed only got to 260 that time replaced alternator new belt topped off coolant ran until 224K when I sold it.
Side note we have a buyer that is buying a large majority of are 6.5 powered trucks and pulling the engines and shipping container after container to Australia they want the engines.
I can not give you a total number of head we have purchased however I will tell you we buy them 8 sets at a time, I have seen a drastic drop in failed heads as most of are old gm engines are about gone and now the majority are a GEP produces engines
Robyn asked if anyone has ever had a failure to speak up. I can tell you I have NEVER had a single failure to date of heads from CCH.
I do not like buying made in China items however it all comes down to the all might dollar if I can buy US for few dollars more I will if it several hundred to thousand more I keeping my green backs.
Here is something to think about I have a friend in the scrap business I asked him few years back why scrap prices have soared ( I'm not complaining) the Chinese are buying everything they can get there hands on on world market driving the price. He went on to tell me that there is only a 2 or 3 day scrap supply on the world markets for certain types of metals mostly going to china.
Who do we have to thank for the loss of US jobs to foreign out sourcing the EPA they have made the regulation to cost prohibitive for are US companies to build new foundries.
Ok I'm done ranting now sorry
				2003 CHEVY 4500 DURAMAX/ALLISON 14'
SERVICE CRANE BODY 16,500 LBS 14.5 MPG
1998 K3500 SRW CREW CAB TRANSPLANTED 6.5TD ELECTROINC INTO, HEATH COMPUTER, 40+HP INJECTORS, 4" EXHAUST, VACUUM ELEMTINATOR ON TURBO,UPGRADED COOLING WITH ALL GM PARTS,NO VACUUM PUMP, SST OIL COOLER LINES MADE LOCALY FRACTION OF THE COST, 3" TOURBO/BOOST GAUSGE ALL IN ONE, ADDED GEAR DRIVE GREAT HELP WITH STARTING TIME DOESN'T JUMP AROUND ANY MORE,  INTERCOOLER 3" INLET AND OUTLET COOLER 12x24x4, ALSO ADDED MANDEL BENT CROSS OVER, HAD TRUCK REPAINTED AND OPUT ON ALUM FLAT BED
