![Quote](images/misc/quote_icon.png)
Originally Posted by
Braveheart
So I took the early advice and had my Kodiak alignment looked at by a tractor pro--a real artisan.
He said that it was not acceptable for an alignment to be neglected by Monroe after such modifications. Mine was not tracking straight in the rear, secondary to a axle which was 1/8" off perpendicular, and you know about the steering wheel already.
Monroe drops these front ends (So-Low) about 2" and then moves the steering wheel about 2 splines one direction or another. On my truck, the wheel was still too far to the right--over corrected. Herein lies a major design flaw. It is my understanding, after my suspension clinic today, that steering boxes operate at their tightest tolerances where the factory zeros the steering wheel. There is a mark on the steering shaft at zero. By moving it 45 degrees, one side or the other, you are begging for sloppy steering and an uneven "feel" and "range" (his words.) Monroe does not install an adjustable drag link to put the steering box back to "zero" ...ever. This effectively lengthens the drag link. So they are begging for sloppy steering and again violating acceptable engineering standards. Looking at the design, I see now why I get bump steer which is worse on left wheel impacts than on the right, add that to the sloppy steering accuracy, and this shows how these could be made so, so much better.
Read: make a DOT-accepted adjustable drag link and you will sell hundreds.
We examined the new Goodyear Highway tires and there was significant tread lateral runout as well as a radial hop in each. This explains the vibration. The balance on one was still not perfect yet. I'm meeting with Goodyear tomorrow; we'll see how they will address this.
I will later measure the input and output angles on the drive shaft to see if they are within 4 degrees or whatever the spec is. This was recent advice.
I don't think the dealer would do this amount of "sorting" even if they are getting the PDI check.
dump those goodyears and grab a set of Yokohama's. just my professional opinion.
Main rig-1978 chevy 3/4 f/t 4x4 8" lift 38 14.5 16 toyo m/t's. BUILT 350(soon to be 6.2) quad batteries. front and rear 15k winches. lockers F/R. dana60 front full float corp 14 rear. th400/np203.
donor rig. 1988 GMC K3500 140k miles, th400. IFS(read CRAP) semi float 14 rear. drove it 142 miles home at 17mpg and 1/4 quart of delo 400.
