Also explain how its worked so far.
I interpret light goes out when dash gauge reads above 32 psi. Is that cold and you are reading what about 60 psi idling then warm it dips to 30 ish psi idling and up to 50-60ish at 2000 rpm the light goes on and off depending on what???
