Patent issues, or?
Patent issues aside, thinking building one for personal use would be cool.
It would have to have some quality bearings. Compressed air, even tapped from turbo compressor, and oil pressure to spin device would work, higher the rpm's the better unit will work.
I'm guessing the unit does not fill up with oil because it works on centrifugal force so a big drain is needed.
I see lots of big machines use this device in concert w/filters so it has value in the oil cleaning department.
