Will the wheels of an 04 2500 fit on my 8 lug 98?
Sold: 98 2500 ext cab long bed 4x4 auto 166k, Lubrication Specialties oil cooler, FSD cooler, Walking J "feed the Beast" mod, Heath HD lift pump, SSdiesel turbo back exhaust, Heath mechanical boost controller, Softtopper camper top, boost, egt, fuel pressure gauges
1970 El Camino SS, built 355, aluminum heads, Lunati cam, intake, 800 cfm edlebrock, Tremec 5 spd, QA1 Coil over all around, Wilwood discs up front, 3.73 Posi 12 bolt, Viper Red
2012 Audi A3 TDI- Love it! 45 mpg!
Yes, several have made the swap
96 GMC 2500 Ext cab Long bed, 8600#, 3.73, Amsoil air filter, amsoil oil, amsoil trans fluid, 3.5 Kennedy Exhaust, 97 airbox mods, EGT, Boost, & Trans Temp on pillar, Heath bumper mounted FSD. Pulling 28' Sprinter 5th
****WANTED BURNED OUT PMD/FSD MODULES FOR EXPERIMENT. ****
1998 Silverado, 6.5TD, 210k, long bed. 1984 Chevy Customized Van, 6.2.
1985 Mercedes-Benz SD, diesel, 220k
1990 Ford, F-250, 7.3 liter, bad engine.
Onan, 4 cyl. Diesel, Marine Generator.
Onan, 4 cyl. Diesel, Stationary Generator.
Onan, 4 cyl. Diesel, Air-cooled Engine.
2 Briggs/Faryman Diesels to rebuild.
Cause they look cooler than the stock steel rims. I got these ones from Les Schawb for $200.
94 GMC 2500 HD
Ext Cab, Long bed
6.5TD, Vin F, 4L80E, 3.73 gears
Pinnacle 4" Exhaust
Heath Diesel Turbomaster
172,000 miles
Thanks! I like the looks of them a lot. That is a really good deal for $200. The cheapest I can find on craigslist or junkyard (car-part.com) is 400. Any other good resources or places to look? Thanks
Go check out different tire shops. A lot of guys are trading in their "stock" HD rims when upgrading. Les Schwab, Firestone, Big O Tires, etc., usually sell them cheap cause they're used.
94 GMC 2500 HD
Ext Cab, Long bed
Pinnacle 4" Exhaust
172,000 miles
