The board is the circuit board underneath the cover. The defect is usually broken solder joints. I have repaired several by just heating and re-soldering ti joints. There is a re-call on the boards. Try the dealer for a replacement, then if that don't pan out, try re-soldering, if that don't work replace it!
96 GMC 2500 Ext cab Long bed, 8600#, 3.73, Amsoil air filter, amsoil oil, amsoil trans fluid, 3.5 Kennedy Exhaust, 97 airbox mods, EGT, Boost, & Trans Temp on pillar, Heath bumper mounted FSD. Pulling 28' Sprinter 5th
