where are you located
a friend of mine has a 85 sub 6.2 that he is scrapping
let us know
Ron
ps I would check batterys and connections. battery is stability in charging system, for you to have charged 25v batterys or connections are probably bad. This is why service manual says do not disconnect batterys when engine is running, alternator can charge 40v without battery in system and fry all your electronics
rhsub 99K2500 suburban 6.5 code F,4L80, 4:10, FSD cooler, DSG oil cooler and lines, Dtech FSD, injectors, Isspro egt, trans and boost guages, Bilistein shocks
